Sponsored by: Kumho
Lowering 78 Bronco
Old Jan 13, 2003 | 03:14 PM
scup's Avatar
scup
Lowering 78 Bronco
I know this will sound nuts to many of you guys with lifted rigs but here it goes. 78 Bronco started out with a 4" lift (coils front, blocks rear)and 35's. My days of off roading over (old age and a crabby woman!)and I want to make the truck a tad more streetable. I've already downsized to 33's and want to bring down the truck another inch or so to fill the void in the wheel wells. The question is there any way to modify the current lift kit to drop it? Possibly cut a coil off the front springs? What about the rear blocks? Thanks for any suggestions.
Old Jan 13, 2003 | 05:25 PM
Ford79's Avatar
Ford79
Lowering 78 Bronco
The front is the hardest part to lower. Cutting the coils is not a good idea. New coils would be the way to go, not too expensive either. The rear is easy, replace the blocks with shorter ones. The shocks should still be ok as well.
Old Jan 14, 2003 | 09:41 AM
tw's Avatar
tw
Lowering 78 Bronco
Old Jan 14, 2003 | 12:27 PM
72f100's Avatar
72f100
Lowering 78 Bronco
Perterson's did an artical where they added 3 1/2" lift springs for a early bronco onto a 79. It gave the fullsize bronco about 2" of lift (perfect for 33's) and rode much better to boot. As far as the rear goes, just take the blocks out.
greythorn3
Offroad & 4x4
13
Jan 24, 2008 09:12 PM
todder53
Offroad & 4x4
Jun 3, 2006 12:35 AM
skips69
Dec 4, 2004 07:01 AM
truckn
1978 - 1996 Big Bronco
Aug 15, 2002 05:08 PM
