Sponsored by: Kumho
How can i do this conversion
Old Jan 10, 2003 | 06:17 PM
erikl85's Avatar
erikl85
I want to change the 8 bold hubs on my f-250 to 5 bolt hubs mainly because I cannot find any damned rims with 8 bolts. Where can I find hubs that would fit properly?
Old Jan 11, 2003 | 05:26 PM
erikl85's Avatar
erikl85
Anyone?
Old Jan 11, 2003 | 06:45 PM
dk5122's Avatar
dk5122
There is a ton of rims out there with 8 lug bolt pattern. You can get them in 16" or 16.5".
Old Jan 11, 2003 | 09:08 PM
erikl85's Avatar
erikl85
Cool, do you have any links? Or a solution to the original problem?
Old Jan 13, 2003 | 03:08 PM
tw's Avatar
tw
I dont have any links handy, but any of the off road magazines have loads of adds for wheels, depending on what you want. Ill bet JC has them. You may have to look for a slightly newer year to be in their databases. Im sure some guys here know how new you can go. You could buy factory wheels on ebay for a newer rig as well.
Tony Warren
Nebraska
Old Jan 13, 2003 | 11:58 PM
Ryan50hrl's Avatar
Ryan50hrl
Newer superduty rims won't fit,,,they are a metric bolt pattern. But try americanracing.com....or tirerack.com for 8 bolt rims. You won't be able to swap 5 bolt hubs over on to a 3/4 ton pick up....
Old Jan 14, 2003 | 09:41 AM
tw's Avatar
tw
[updated:LAST EDITED ON 01-14-03 AT 10:51 AM (EST)]Anything up to a superduty should work for ya. There were lots of those with factory aluminum rims in the 90s.
Also you could go to Summit Racing, they have some.
Dont know, the name might be deleted by administrators.
Tony Warren
Nebraska
Old Jan 14, 2003 | 10:21 AM
rebocardo's Avatar
rebocardo
Assuming you have 15" rims and want to stick with that.
How is this:
http://www.stocktonwheel.com/
http://www.championwheel.com/
http://www.tyres1.com
82 Series White Monster
stock# 82500804
I think this is 15x10, 8x6.5, 4" backspacing. $64. What you need?
Give them a call.
Old Jan 14, 2003 | 01:07 PM
erikl85's Avatar
erikl85
Great!! tyres1.com had the exact wheel i wanted but with an 8 lug pattern. These trucks are 8x6.5 correct?
Old Jan 14, 2003 | 04:05 PM
Ford79's Avatar
Ford79
Yep. Good to see you found what you were looking for.
Old Jan 14, 2003 | 06:13 PM
mcomstoc's Avatar
mcomstoc
4wd Low
