Sponsored by: Kumho
Helper springs
Old Jan 12, 2003 | 10:14 AM
Jim Dandy's Avatar
Jim Dandy
Helper springs
I plan on occasionally carrying a slide-in popup camper that will bring me near to GVWR, and wonder if some type of helper springs on the rear would be of benefit. 90% of the time I'll be running around unloaded, and do not want to adversely affect the ride. Anyone have an opinion or experience with:
Steel Leaf helper springs like [link:www.hellwigproducts.com|Hellwig], or
Air helper springs like [link:www.ride-rite.com|Firestone Sport-Rite].
Thanks - jd.
2003 F150 XLT SuperCab 4X4 6½' StyleSide, 5.4L Auto 3.55LS
Old Jan 12, 2003 | 11:00 AM
DCSpecial's Avatar
DCSpecial
Helper springs
I'd go with the Firestone Bags. Won't affect ride when unloaded, but air them up to level out the load and improve the ride. They work great.
Hope this helps.
Old Jan 12, 2003 | 08:02 PM
PHS79's Avatar
PHS79
Helper springs
I would say go for the airbags, I have leafs under my truck, next time I am going to go for bags myself.
Old Jan 12, 2003 | 08:30 PM
MustangGT221's Avatar
MustangGT221
Helper springs
Bags would be the best idea, but remember, they do NOT increase the weight that you can carry. They only allow you to level off the rear end of the truck when you put a load on it, and it will ride better when loaded.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Old Jan 14, 2003 | 08:39 PM
wabiker's Avatar
wabiker
Helper springs
Ive used the hellwig progressive rate helper springs on my 79, worked great for me...they only kick in when yer loaded so the ride isnt affected as bad as standard overloads...
$.02
Old Jan 15, 2003 | 05:16 AM
dk5122's Avatar
dk5122
Helper springs
Old Jan 18, 2003 | 10:17 PM
MICOTIL's Avatar
MICOTIL
Helper springs
I DRIVE A 1999 F-250 SUPERDUTY REGULAR CAB 4X4 WITH THE POWERSTROKE DIESEL, RANCHO RS 9000 SHOCKS AND 315/75R-16 BUCKSHOT MAXXIS MUDDER TIRES. ABOUT 2-3 TIMES A WEEK I PULL A 2-HORSE GOOSENECK SUNDOWNER TAILER THAT HAS A DRESSING ROOM 1-2 HOURS TO AND FROM HORSE SHOWS/LESSONS. I NOTICED WHEN THE TRAILER WAS ON THE TRUCK(LOADED WITH 2 HORSES AND TACK) THAT HE TRUCK HAD THE LOOK THAT IT WAS DRAGGING ITS REAR DOWN THE ROAD. I WAS ALSO WORRIED ABOUT PREMATURE WEAR OF THE SUSPENSION FROM THE LOAD SO I INSTALLED HELLWIG LP-35 HELPER SPRINGS. THE RIDE OF MY TRUCK WHEN IT'S NOT LOADED IS A LITTLE MORE FIRM, BUT NOT THAT NOTICEABLE WHILE THE BENEFIT IS VERY NOTICEABLE WHEN PULLING THE TRAILER.(LESS MOVEMENT OF THE TRAILER). THE SPRINGS ACTUALLY RAISED THE REAR OF MY TRUCK ABOUT 1 INCH AND ONLY COST ME 270.00 DOLLARS.
chappys4life
16
Apr 20, 2012 01:28 PM
carrfamilynj
Oct 15, 2011 06:26 AM
mikedeason
Nov 7, 2006 12:58 AM
Gt-358
Jun 18, 2006 05:01 PM
Benoit1967
2004 - 2008 F150
18
Feb 8, 2006 04:23 PM
