solid flywheel kit 89-97 ??
Old Oct 22, 2008 | 05:17 AM
ola1234's Avatar
ola1234
I am going to put an -89 ZF-5 in my -91 truck. And now I have a cheap solid flywheel and clutch on hand. But it is listed for 94-97, which is for the powerstrokes. Will this set fit my set-up??
Another question; I have got 285-75-16 tires on it now. What would this be in inches? And how big tires is it possible to put on these rims?
Old Oct 22, 2008 | 07:38 AM
ghunt's Avatar
ghunt
About the tires: a 285/75R16 is roughly equivalent to a 33x10.50.
Do you still have the stock wheels on the truck?
A 285/75 is really too wide for a stock wheel, an 8-9" wide rim is recommended for them.
Old Oct 22, 2008 | 08:17 AM
ola1234's Avatar
ola1234
No, I don`t have the stock wheels on. But I am not sure about the size of the ones that are on it now. The reason I ask is that I wonder if 285-75-16 will be to small with a 4" lift.
Old Oct 22, 2008 | 09:13 AM
ghunt's Avatar
ghunt
Probably...
33" tall tires fit on a stock truck, so with a 4" lift you'd probably want 35's.
Old Oct 22, 2008 | 04:33 PM
Dodge/Cummins's Avatar
Dodge/Cummins
I'm pretty sure the SMF system will work on your truck/motor/trans. combo but somebody will be on to say for sure.
Old Oct 23, 2008 | 09:01 AM
ola1234's Avatar
ola1234
Anybody who can confirm that the 94-97 SMF-clutch will work on my 89-91 set-up?
huggyb1972
Jan 23, 2014 05:03 PM
FordOwnerJoey
Oct 5, 2013 07:34 PM
Big block bronco
Jun 18, 2010 03:06 PM
fordmudrunner2020
Apr 26, 2005 10:47 PM
Darryl
Aug 12, 2003 09:39 PM
