Creaking noises coming from ft. left...
Old Oct 21, 2008 | 10:32 AM
Ford554's Avatar
Ford554
pretty much under your left foot. A friend told me there's a TSB on the body mounts but i haven't found anything. Has anyone else ran into this problem.
It definitely feels like a body mount, it creaks a lot when doing slow turns and now starting to creak on acceleration.
Old Oct 21, 2008 | 01:20 PM
Aatcntrl1's Avatar
Aatcntrl1
I have the same propblem. I've searched everywhere and can't find it. If you do find it please let me know.
Old Oct 21, 2008 | 04:19 PM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Mine too, but it's under both the driver and front passenger foot. There seems to be body mounts located in that spot, but they don't have a nut or bolt, it looks like a push in type of rivet. What's a TSB?
Old Oct 21, 2008 | 05:07 PM
BAJI26's Avatar
BAJI26
The body mount are bolted... remove the carpet and remove the grommet. I need some also.
Old Oct 21, 2008 | 07:46 PM
Ford554's Avatar
Ford554
Originally Posted by sddesigns
What's a TSB?
TSB(Technical Service Bulletin)
I'm pretty slow this week at work. I might just order the two fronts, install them and see if the creaking goes away. I'll try to take a few photos.
Old Oct 21, 2008 | 09:07 PM
VaSheriff's Avatar
VaSheriff
If I am sitting in the third row, is it still under my left foot?
Isn't this a sympton of bad ball joints too?
Old Oct 21, 2008 | 09:14 PM
BIG BOI's Avatar
BIG BOI
Really, I too experience that when i do slow left hand turns, strange, so what is this bump under my foot?
Old Oct 22, 2008 | 08:11 AM
Ford554's Avatar
Ford554
Old Oct 22, 2008 | 07:15 PM
SUV KING's Avatar
SUV KING
My 2002 started doing the same creak and clunk a few months back. Turned out to be the sway bar bushings. Swapped them out with polybushings from energy suspension. Cost about $20.00 at autozone. No more creaks or clunk.
Just thought this might help.
Old Oct 22, 2008 | 08:27 PM
ExcursionSVOand5.0's Avatar
ExcursionSVOand5.0
Mine does the same thing....drives me crazy....asked the dealer to find it and fix it to no avail.
Old Oct 23, 2008 | 08:15 PM
X-70STANG-F150's Avatar
X-70STANG-F150
I had the same thing, but it was the radius arm bushings. but I have 2wd. I assume the 4wd has simillar control arm bushings.
Old Oct 24, 2008 | 08:05 AM
Wilson & Co's Avatar
Wilson & Co
sway end links or ball joints... either are relatively easy to diagnose if you have a repeatable noise...
bigblueexcursion
Apr 10, 2017 09:32 AM
SkyHigh4x4
Mar 22, 2017 08:38 PM
chesster51
Apr 12, 2016 04:39 AM
firedaniel
Apr 4, 2015 06:31 PM
jagarcia89
2004 - 2008 F150
Jul 1, 2012 02:50 AM
