oxygen sensor problem
Old Oct 20, 2008 | 04:02 PM
einsteindog's Avatar
einsteindog
I have a 1994 Ford F-150 V-8 5.0L. I recently replaced The Battery Cables in my truck. Now the check engine light comes on.I checked the code reader and 172-oxygen sensor lean.I repplaced with a new one.The check engine light keeps coming on and showing the same code.I erased the code, was ok going to work this morning.On the way home the check engine light came on again,checked code reader,same code. Any suggestions?
Old Oct 20, 2008 | 07:31 PM
jr32560's Avatar
jr32560
sounds like to me the truck is running lean-the o2 sensor is just picking it up!maybe a vacuum leak?
Old Oct 20, 2008 | 07:37 PM
jr32560's Avatar
jr32560
try this-may help
Go here > Bedford Public Library -- AARC < to get any maintenence manuals you may need. They have the electrical schematics too!!! Use the user name..... " library" and the same name for the password. "library".
complement of Bud from the M.d chapter
code 172 is hego always lean-that is I believe the egr valve!
Old Nov 26, 2008 | 03:42 PM
einsteindog
Need help. Check engine light still on. Driving down highway about 65mph. Check engine light went off(yeah). Started losing power, stepped on gas wouldn't go any faster. Started hearing a popping noise coming from the engine. Kept doing this all the way home.Checked the code reader. Its still saying(172) o2 running lean, but its also saying 173 o2 running rich. Does this happen when the computer is resetting itself? Its not fun.
Old Nov 26, 2008 | 03:50 PM
skaterbro's Avatar
skaterbro
You should've tested the HEGO first, i'm guessing it wasn't your problem. Have you checked the FPR? Test first, THEN replace.
Old Nov 26, 2008 | 03:57 PM
einsteindog
Whats a FPR?
Old Nov 26, 2008 | 03:58 PM
skaterbro's Avatar
skaterbro
Fuel pressure regulator
Old Nov 26, 2008 | 04:03 PM
einsteindog
Can you give me a hint where its located?
Old Nov 26, 2008 | 04:41 PM
skaterbro's Avatar
skaterbro
Oh sorry bud, figured you had a manual. Driver side fuel rail near the firewall.
http://partimages2.genpt.com/partimages/263792.jpg
Definitely get a book if you don't have one. They come in real handy.
Old Nov 26, 2008 | 04:44 PM
einsteindog
Thanks, I'll check it out tommorow.
Old Nov 29, 2008 | 02:38 PM
einsteindog
Angry
ok. So I went out and purchased a fuel pressure gage. The first time I checked it everything was well within specs. The second time I checked, The front tank dropped to 32psi, the range is 35 to 45psi. So could it be the fuel pump? The truck feels like stalling during idle.
Old Nov 29, 2008 | 09:14 PM
Conanski's Avatar
Conanski
Code 172 is "HEGO sensor circuit indicates system lean (right side)" That's not a O2 sensor problem, that's a fuel problem. Sounds like you may have a bad pump or clogged fuel filter from those pressure tests.
Old Nov 30, 2008 | 08:30 AM
einsteindog
I rechecked the fuel system this morning and have hardly any pressure with either tank.
Old Nov 30, 2008 | 08:40 AM
Redcat Diesel's Avatar
Redcat Diesel
You might try replacing the fuel filter first since the pressure is low on both tanks. The odds of both pumps failing at the same time are minimal.
I'm trying to correct a PO171 code in my 96 so I'm checking most of the same stuff.
Old Dec 5, 2008 | 08:14 AM
einsteindog
Replaced the fuel filter. Took truck for a ride. CEL came back on(would miss it if it wasn't there). Ran the code. Not only did 172 come up again but nowcode 157 MAF low voltage is showing up.
