No power steering
Old Oct 20, 2008 | 03:35 PM
t.Rowley's Avatar
t.Rowley
No power steering
The other day I had to push the truck cause the battery went dead, thats not the problem. This is a 78 f 150 with a 460 engine. Before the battery went dead I had power steering, then after pushing it and steering it for alittle while without the truck running I now have no power steering. I know weird! I replaced the pump twice now, so what do you think? Did I blow the power steering hose and have a leak, there are alot of bubbles, or did something happen to the steering box?
Old Oct 20, 2008 | 04:31 PM
F250army45d's Avatar
F250army45d
If you have lots of air bubles it sounds you may have sucked in some air. Are there any puddles under the truck that would say if a hose broke. Check for signs of fluid leaks if you don't see any trine bleed the air out.
