Rotating tire question
Old Oct 20, 2008 | 12:10 PM
02GrayPowerStroke's Avatar
02GrayPowerStroke
Is it ok to just swap the front to rear when doing a tire rotation?
Old Oct 20, 2008 | 12:15 PM
rebelchevy02's Avatar
rebelchevy02
I alway have used the following method.
Old Oct 20, 2008 | 01:10 PM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
I'd do it that way too, but you have to have the truck completely off the ground to switch them that way. I've always just switched back to front and front to back
Old Oct 20, 2008 | 01:15 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
I always go front to back.
Old Oct 20, 2008 | 01:29 PM
husker's Avatar
husker
I do the cross rotation. I jack up the back and put it on jackstands and then use the floor jack to change the fronts one side at a time. I always loosen the lug nuts before jacking up anything on the truck or they can be tough to get loose.
Old Oct 20, 2008 | 01:34 PM
rebelchevy02
It actually only requires two jacks. One front at a time, and the other jack below the center of the differential. Move the front jack to the other side after that one has been switched to the rear.
Old Oct 20, 2008 | 01:36 PM
danskool's Avatar
danskool
Go Bills !
I just do front to backs. I have little arrows on mine.
Old Oct 20, 2008 | 01:51 PM
superduty4x4's Avatar
superduty4x4
Cross the fronts, bring the rears straight forward. That's how I do it, and thats how my dad did it for 16 years when he managed a tire store. Directional tires are something I never have (nor ever hope to) mess with.
Old Oct 20, 2008 | 02:02 PM
big poppa's Avatar
big poppa
Front to back also but thats a good point with directional tires, go to the other side and you have the tires going the oppisite direction, right??
Old Oct 20, 2008 | 02:06 PM
rbaker6336's Avatar
rbaker6336
I tried doing mine front to rear but looked really silly
I don't bother anymore
Old Oct 20, 2008 | 02:08 PM
02GrayPowerStroke
Thanks for the info
Old Oct 20, 2008 | 02:17 PM
danskool's Avatar
danskool
Go Bills !
My tires are almost bald. An even bald. It apears my truck runs pretty tight and straight. When rotating tires from the previous owner and i had her all jacked up. I noticed the arrows. I thought DANG... Jacked all 4 corners for nothing.
Right. The reason i only went from fronts to back. My Wifes focus is the same way..
Old Oct 28, 2008 | 03:19 PM
snakyjake's Avatar
snakyjake
I don't rotate my tires. Usually the front tires wear first. So I buy new tires for the back, and take the back and put on the front.
So I only have to buy two new tires ~80,000 miles.
Old Oct 28, 2008 | 03:22 PM
PwerStroke99's Avatar
PwerStroke99
thats how i have always done my tire rotations too
Old Oct 28, 2008 | 05:05 PM
brian42's Avatar
brian42
Veteran: Navy
I've always brought the rears straight forward and the fronts straight back. If tire wear is looking uneven then I will cross going back (from front to opposite rear) to try and maintain even tire wear.
That's the rule of thumb I use: I only cross when going TO the drive wheels. Hence a FWD vehicle I will cross when going from rear to front (as I do on my wife's Santa Fe).
Just my .02
