Do LED's need different blinker fluid?
Old Oct 20, 2008 | 08:16 AM
SkySkiJason's Avatar
SkySkiJason
Blinker fluid? I am condemned to hell for all the blondes I sent to the auto parts store to get 'blinker fluid'. Is it too late to repent?
I just changed to LED's on headache rack. I guess enough of my bulbs are LED's now that the flasher is mad. I'm getting super-fast blinking. Are there different flashers for LED's that 'drop in' yet? I've seen the LED 'fix' thingys, but don't they just add some load to make flasher happy again?
Old Oct 20, 2008 | 08:22 AM
F350-6's Avatar
F350-6
I've heard that the synthetic blinker fluid is required if you have LED's.
I remember reading about LED's not having a big enough amp draw for some flashers to work properly. I don't remember if it's as simple as just a relay swap, or what the fix is. I'm mostly subscribing for future reference.
Old Oct 20, 2008 | 08:55 AM
rpenterics's Avatar
rpenterics
Not sure on the amp draw but you can get some high quality synthetic blinker fluid here - Blinker Fluid [BF-01] - $8.99 : KaleCoAuto, Hard to find automotive items!
Old Oct 20, 2008 | 08:59 AM
superduty4x4's Avatar
superduty4x4
With LED's you do need to change blinker fluid to the higher viscosity fluid, the lower draw of the LED's is compensated for by the higher viscosity of the fluid. Another trick, though not quite as effective, is to install a blinker fluid cooler to help thicken the blinker fluid.
Ryan that web site is priceless, thanks for the link!
Old Oct 20, 2008 | 09:01 AM
indebt's Avatar
indebt
Old Oct 20, 2008 | 09:07 AM
rbaker6336's Avatar
rbaker6336
Grote makes flashers for LEDs
Grote Industries: Flashers and Turn Signal Switches
Old Oct 20, 2008 | 09:13 AM
Izzy351's Avatar
Izzy351
I was gonna suggest a heavy duty relay, since lots of lights will do that, but it seems like the reverse is happening??? And on top of that, I would assume a vehicle build for pulling would have a relay in there suitable to handle extra lights... I'm curious what fixes this now too...
Old Oct 20, 2008 | 09:17 AM
rbaker6336's Avatar
rbaker6336
this one would probly work for most
Grote Industries: Product #44891 - Flasher
Old Oct 20, 2008 | 09:29 AM
schlepprock250's Avatar
schlepprock250
Someday...I'll get a Round Tuit.....
Old Oct 20, 2008 | 09:31 AM
superduty4x4
I have several of them, but they are all being used
Old Oct 20, 2008 | 10:32 AM
cc_rider's Avatar
cc_rider
I have TRIED to put LED 'bulbs' in the overhead lamp in the truck. They work fine for awhile, then they start doing this 'strobe light' effect, flashing like crazy. Super annoying, since I paid a small fortune for the little bastidges. Swapped 'em out too, and the new ones eventually did the same thing.
c.
Oh yeah: you don't need none-a that fancy-schmancy blinker fluid, plain ol' bear grease'll work jes' fine.
Old Oct 20, 2008 | 10:49 AM
DieselCamper01's Avatar
DieselCamper01
That is flippin hilarious!
Old Oct 20, 2008 | 11:03 AM
aklim's Avatar
aklim
I happen to have a few bottles of Extra Virgin Synthetic Blinker Fluid. Not to be confused with the cheap imitation stuff. So, if you want some, let me know. Please OM me so I know you are a member and I will give you the member discount price.
Old Oct 20, 2008 | 12:15 PM
Vinford's Avatar
Vinford
One my 1ton flatdeck its got a bunch of lights on the deck, along with cab lights and a few other lights.
It burned out the headlight switch and almost caused a fire...........
so I went with LED's and now nothing works proper , so I guess theres no happy medium.
Old Oct 20, 2008 | 12:21 PM
rbaker6336's Avatar
rbaker6336
you could use a couple relays and not run all the amperage through the switch
