Tranny trouble!!!
Hope you all have had a good weekend. I have a quick question. How exactly can one tell if a new clutch, throw out bearing, or pressure plate is needed for sure? I finally got my truck back running, and found out why my shifter broke off. It will not go into any gear I try to put it in!!! It grinds as if I am not pushing the clutch at all. And, sometimes, the engine starts lugging down like I am letting off the clutch, but I am not. At first I though it might be out of adjustment, so I crawled underneath and looked at the adjustment rod and found that it was adjusted all the way out already. It was doing great, but that one day it just wouldn't go into gear and I had to force it in to prevent being hit and the shifter broke. I just found out this week end that it may be something internal. I am not too experienced with trannies at all. I do not want to go and buy a clutch and all with out knowing for sure thats what it is......not much money right now but I need my truck for work. And one more thing. One time when I went out to start it, I had the clutch to the floor and as soon as the starter engaged, the truck moved a little. I just need to know how to make sure what is wrong before I buy anything. Any help would be appreciated.
Michael
I'm not real experienced with that stuff either but kinda sounds like either your clutch is bad or the syncronizers are out on your transmission.
good luck
mcovington - if the truck moved when you cranked the starter, your clutch isn't disengaging. This happened on a friend of mine's. What I would suggest is you post this in the clutch\transmission forum, because while this forum is specific to 73-79 Fords, this sounds like a problem related to clutches and transmission in general. I say this because I talk to some guys over on that forum that are really sharp and should be able to help you out. Here is a link to that section of the website.
https://www.ford-trucks.com/forums/forum69/
Apologies,
Michael
Last edited by mcovington; Oct 19, 2008 at 09:51 PM. Reason: Posted to wrong response
I will do just that, because I tansmissionly challenged! LOL. I wouldn't think the syncros are are out because I just had this transmission put in about six months ago, but it's not impossible I don't guess. Thanks for the link and I will use it.
Michael
--inspect under the dash where the pedal pivots and all related linkages and brackets.
--inspect under the truck, again, all linkages and attachments right up to the bell housing pivot.
Bending, cracked, weakened components will give you this kind of trouble.
1980's trucks had problems with firewall flex. If yours has any rust, you may have that issue.
Good luck & I hope I have understood your post correctly.
