1990 F-150 stalling
Old Oct 19, 2008 | 12:51 PM
kelboy1971's Avatar
kelboy1971
1990 F-150 stalling
I have a 1990 F150 4x4 with the 5.8, it used to run fine now it idles really rough and bearly has enough power to pull it's self, and when I do get it up to speed it stalls when I get to a red light. I have recently changed the MAP sensor and coolant sensor. What else could it be? how do I check for codes? any help would be great, thanks guys.
Old Oct 19, 2008 | 01:25 PM
McLeod's Avatar
McLeod
This site will guide you through the code retrieving process: Ford Fuel Injection How To Run a Self-Test
Old Oct 20, 2008 | 09:46 AM
G/T's Avatar
G/T
Tps,(trottle Position Sensor)maybe,i'm Just Guessing.mine Does The Same Thing.replaced The Coolant Sensor,module,stator,coil,wires,spark Plugs,cap,hollowed My Cat,new Muffler,air Filters,cleaned My 02 An Iac.next Will Be The Tps,pulled Codes Said That The Egr An Or Sensor On Egr Was Bad.cant See An Egr Making It Run So Bad.next Step, Buy A Toyota.
Old Oct 20, 2008 | 11:12 AM
rattosh51's Avatar
rattosh51
Could be a fuel pump....or many other things.
Old Oct 20, 2008 | 12:34 PM
jroehl's Avatar
jroehl
Codes first...and on a '90 they will be 2-digit.
Jason
Old Oct 20, 2008 | 12:46 PM
danr1's Avatar
danr1
<i>it idles really rough and bearly has enough power to pull it's self, and when I do get it up to speed it stalls when I get to a red light.</i>
My "off the top of my head" guess after reading that would be the EGR valve is stuck open a little.
That is if its not in a dire need of a tune up.....
Old Oct 20, 2008 | 08:21 PM
83stepside32784's Avatar
83stepside32784
Bad or cracked spark plugs...or bad wires...alos make sure your 7 and 8 wires aren't arcing off of each other....
Radconpro
13
Feb 7, 2020 06:18 PM
TurtleTruckSC
Mar 30, 2014 12:34 PM
RDouglas
1997 - 2003 F150
Apr 22, 2009 08:39 PM
ssamduran
Nov 22, 2006 09:05 PM
Todd
Jul 30, 1999 07:54 AM
