rough idle after head install
Old Oct 18, 2008 | 10:05 PM
sheamus's Avatar
sheamus
I just finished putting the finishing touches on my head swap today. I started it up and it started fine but the idle is extremely rough, the whole engine shakes from side to side. Is this a timing issue or do I have a compression issue? Its a 1981 with the 300. any input is greatly appreciated!!!
Old Oct 18, 2008 | 11:55 PM
fmc400's Avatar
fmc400
MSEE
Try spraying around the intake-to-head surface with a can of carb cleaner spray while the engine is idling. Try each runner, and be careful not to get it on the exhaust manifold. It may be safer to do this with the motor cold, before the exhaust heats up a lot. If the idle jumps up, then the problem might be a vacuum leak.
Old Oct 19, 2008 | 05:46 AM
Motorhead351's Avatar
Motorhead351
Id check the the valves/rocker adjustment again.
Old Oct 20, 2008 | 08:45 AM
sheamus's Avatar
sheamus
I took off the valve cover again and checked my torque settings, they were all torqued to factory specs, nothing seemed out of the ordinary. I also timed it and when I'm at idle i have to keep giving it gas or else it sputters and dies.
Old Oct 20, 2008 | 10:13 AM
fmc400's Avatar
fmc400
MSEE
Did you check for vacuum leaks?
Old Oct 21, 2008 | 07:33 AM
Motorhead351
Would it seem I was a jerk, if I ask, did you torque them at TDC
Old Oct 22, 2008 | 09:18 AM
sheamus's Avatar
sheamus
I did torque them at TDC....I finally gave up and dropped it at the mechanic, turns out I have one of the worst exhaust leaks he's ever seen. He said it wasnt due to my fault, the manifold needed to be resurfaced and my gasket was probably faulty, should have the truck back by tomorrow! Thanks for all the help guys.
metmop
Aug 5, 2014 11:00 PM
BrentElliott0093
1997 - 2003 F150
Apr 14, 2014 05:33 PM
429poweredf350
Apr 9, 2011 06:13 PM
curtismstang
1983 - 2012 Ranger & B-Series
15
Mar 21, 2007 09:37 PM
