Bronco II Ford Bronco II
Throttle Position Sensor Codes
Old Oct 18, 2008 | 09:46 PM
fordtrucksj's Avatar
fordtrucksj
Hello everyone. Here's what's going on. I have an 89 2.9L 4X4 Manual transmission. It suddenly began to idle at 1100 RPM. I've ruled out the ECT, IAC, basic tune up stuff like the rotor, wires, plugs, cap, and the timing is fine. So, I pulled the codes and it came back with the following codes:
63 (Continuous Memory code) which I think is a "throttle position circuit fault, below minimum voltage"
but then another code came in
53 (Continuous Memory code) which I think is a "throttle position circuit fault, above maximum voltage" reading.
Another note is that it does idle at 850 RPM from time to time (normal) and when I unplug the TPS, the RPMs do drop---so having said all of this--what's with the contracdicting codes? ---max and min voltage readings. Is the sensor bad? Is a short? Is there a fuse I don't know about? Should I replace the senor? It's 33+ tax at Autozone. HELP.
Thank you all for any feedback.
Old Oct 18, 2008 | 11:09 PM
mrshorty's Avatar
mrshorty
I would probably check through the wiring to/from the TPS. Make sure the TPs is seeing a steady 5 V Vref and not getting a shaky voltage. TPs is a simple potentiometer, so it wouldn't take much to put a voltmeter on it and see if it shows any "breaks" or "flat spots".
Old Oct 19, 2008 | 01:05 AM
fordtrucksj
How to check TPS for steady 5 V Vref
How do I do this? Electrical is my MAJOR weak spot. What tool do I use and how do I go about it. If you can explain it, I can do it--I just need to know how and where to start. I appreciate the help you have given me over the years mrshorty.
Old Oct 19, 2008 | 09:36 AM
Bear River's Avatar
Bear River
Former ******
Look, if your wiring looks good, and there are no signs of corrosion at the connector, then the codes are probably right on the money. If it were me, I would get a new one and install it. I have never seen a TPS code be anything other than a bad TPS.
Old Oct 19, 2008 | 11:45 AM
fordtrucksj
TPS codes / Replacing the TPS
I'm going to go for it and replace it. The harness is in great shape and I had it refurbished about 1 1/2 years ago. No signs of cracks or anything. The sensor is only two years old--I bought it at Kragen--is it possible that it went bad in only two years---or perhaps it was just a bad sensor from the get go? Thoughts? Thanks Bear River
Old Oct 19, 2008 | 12:01 PM
97Centurion's Avatar
97Centurion
Rub my Belly
I just got done replacing a 3 year old fuel pump if that tells you anything about "new parts." Thank goodness for "lifetime" warranty's or it would have cost me a $100 bill.
Old Oct 19, 2008 | 02:00 PM
Bear River's Avatar
Bear River
Former ******
I have found that if I stuck with brands that also make OE stuff, that I get better products (Bosch aside). I buy Motorcraft when I can, but AC Delco seems to be pretty good too.
Old Oct 19, 2008 | 11:46 PM
fordtrucksj
Thanks for the info. I have heard some pretty good stuff about AC Delco.
Nick1236
Dec 19, 2009 10:05 PM
sonora pass
1983 - 2012 Ranger & B-Series
Feb 19, 2009 01:09 PM
KTofCO
Modular V8 (4.6L, 5.4L)
Feb 20, 2006 01:51 PM
Rubbersoul
Dec 10, 2004 02:51 PM
steve83
Computer Chips & Tuners
May 19, 2003 05:50 PM
