Cold Start Problem
Old Oct 18, 2008 | 07:10 PM
REDBUD's Avatar
REDBUD
thanks what do you think about the throttle pedal not functioning until engine gets to operating temperature.
Old Oct 18, 2008 | 07:16 PM
F350-6's Avatar
F350-6
A loose UVCH will usually throw a P1316 and the CEL. Have you tried the buzz test when the engine is cold? Have you monitored ICP pressure and % while cranking? You might want to monitor ICP % (really IPR) to see what that does and how it changes when the engine warms up.
Sorry about the MAP question. I see you already mentioned that in an earlier post.
megawatt00's Avatar
megawatt00
I'm not to sure on that. Have you checked the oil level in the HPOP before you try to start it in the morning?
Old Oct 18, 2008 | 07:22 PM
REDBUD's Avatar
REDBUD
yea it's within 3/4" from the top
Old Oct 18, 2008 | 07:24 PM
megawatt00's Avatar
megawatt00
OK that rules out that
Old Oct 18, 2008 | 07:51 PM
F350-6's Avatar
F350-6
The 2 things that come to mind off the top of my head are either a bad TPS or a sticking IPR or o-rings leaking on the IPR(hence checking the ICP % on the scanner)
Old Oct 18, 2008 | 07:53 PM
megawatt00's Avatar
megawatt00
Chris, Dumb question....How would the TPS not run correctly until the engine comes up to temp?
Old Oct 18, 2008 | 08:15 PM
REDBUD's Avatar
REDBUD
also even when its up to operating temperature there is little power until you drive it awhile. low power from 0 to 30 mph.when turbo kicks in there is lots of power and is smooth.if you run it hard for a few minutes the low end power comes back to life. hope i discribed that so you can understand its easyer for me to speak it than to type it.
Old Oct 18, 2008 | 08:17 PM
F350-6's Avatar
F350-6
I can't think of a single reason, but it's an electrical sensor, so it's out of my league. But pushing the pedal with no response either means the signal is not going out, or it's not being received at the other end of the wires. Maybe we should ask an electrician.
Old Oct 18, 2008 | 08:20 PM
megawatt00's Avatar
megawatt00
Do you know of any?
I'm going to see if I can find any info on the where's and how's of the TPS
Old Oct 18, 2008 | 08:29 PM
REDBUD's Avatar
REDBUD
thanks for your help guys i hope you don't give up on me i can't afford shop fees right now and i am really stumped on this one.just a shot would injector popits or o-rings cause any of this.
Old Oct 18, 2008 | 08:35 PM
F350-6's Avatar
F350-6
Injector poppets will can perform poorly with cold engine oil (buzz test when cold), then start to sound better if you buzz test them a few more times. This is usually seen with high mileage injectors, or those that have had poor maintenance schedules on the oil changes. Injector o-rings usually cause some smoke. Do you have any smoke while this is going on? If so, what color?
Out of curiosity, if you remove the oil cap with the truck at idle, what kind of blowby do you see?
Old Oct 18, 2008 | 08:42 PM
  #28
megawatt00's Avatar
megawatt00
This is all I can find (quickly) on the TPS
Irregular Engine Idle Speed (Diesel)
Incorrect engine idle speed adjustment or idle validation switch.
REPLACE the accelerator pedal and sensor assembly.
Old Oct 18, 2008 | 08:43 PM
  #29
REDBUD's Avatar
REDBUD
a steady wisp out of the filler cap and puffs of whiteish blue smoke when you hit the pedal and the engine flutters a little then puffs and clears up.does not smoke at idol.only smokes when you hit the pedal the engine will stumble and flutter a bit then clear. 170000 miles
51f1truck
34
Sep 11, 2019 01:52 PM
hornychief
1997 - 2003 F150
Jan 28, 2014 08:23 PM
Rhino99
Modular V10 (6.8l)
May 10, 2012 11:58 PM
jeeplj8
Jul 11, 2011 08:54 PM
DetailerDave
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 24, 2005 08:18 PM
