Sponsored by: Real Truck
Done something stupid!!!!!!!!
Old Oct 18, 2008 | 03:35 PM
scottm1's Avatar
scottm1
I was working on my 02 Super Duty diesel this weekend, and since I was going to have the doors open for an extended time I decided to unhook the batteries to keep the batteries from running down. When I disconnected the neg cable on the left side battery and started to go to the right side to unhook that one, the neg cable I just unhooked on the left side came loose and went back and touched the positive post on the battery. Obviously there was an arc that got my attention and I got it away from it very quickly, but now after that my power windows and radio will not work anymore. I have been reading on here about the GEM causing these items not to work if the voltage is too high or too low. I checked my battery with a load tester and they check ok and are fully charged. I checked all of the fuses and they are all good. Did I fry the GEM? Is there something else I should look for? I am mainly a wrench turner on Chevys and am a little out of my element working on a Ford. Anybody have a direction to point me in??? Thanks!!!!!!!!
Old Oct 18, 2008 | 08:36 PM
BillyBob69's Avatar
BillyBob69
You could try resetting the GEM to see if it helps. Remove the bolts holding the fuse panel in place and you can turn it enough to unplug the GEM. Let it sit for about 5 minutes, plug it back in a try again. Worth a shot....Did you also check the fuses under the hood in the main boz? (Next to the master cylinder on the drivers side.)?
Old Oct 18, 2008 | 10:01 PM
scottm1's Avatar
scottm1
Nevermind, I found what it was. The instrument cluster fuse was blown that I had overlooked before. Obviously I am glad it wasn't something much more expensive!!!
Old Oct 19, 2008 | 06:25 AM
ken kenmnedy's Avatar
ken kenmnedy
You dont have to unhook the batt. these trucks have a batt saver switch on them. that cuts off the power to the truck when the battery get to a certen level
Old Oct 19, 2008 | 02:36 PM
someday's Avatar
someday
they dont have a battery saver...if u leave your doors open after a certain amount of time it will kill that but that it
Old Oct 19, 2008 | 03:02 PM
ken kenmnedy
it says in my owners manual that it does I didnt make this up !!!!!
Old Oct 19, 2008 | 03:27 PM
senix's Avatar
senix
I think some of the conflict might be the newer the truck then it may have other options. My 08 F250 has power saving features on it.
Old Oct 19, 2008 | 10:42 PM
BillyBob69's Avatar
BillyBob69
It is always nice the even when Murphy's Laws try to step in, they can be foiled sometimes. Nice find!
Old Oct 20, 2008 | 10:39 AM
riggz's Avatar
riggz
what page? i'd like to read this.
Old Oct 20, 2008 | 01:16 PM
someday's Avatar
someday
i really didnt want to read through my owners manual for something im pretty sure wasnt there...if there is something malfunctioning and is drawing power from the battery there is nothing to prevent it from completely killing the battery
Old Oct 20, 2008 | 03:29 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
They call the lamp timeout a "battery saver"
Old Oct 20, 2008 | 05:01 PM
ken kenmnedy
yup you guys are right thats what I thought was a battery saver went through the manual cover to cover not a word about a battery saver in there.... wouldnt save a direct short anyway
Old Oct 20, 2008 | 05:51 PM
tnau664's Avatar
tnau664
Don't feel bad Ken. The first time my interior lights timed out I thought I had blown another fuse. (I was working on one I knew was blown at the time.)
You learn something everyday.
Terry
ovalhead72
16
Jun 7, 2014 03:53 PM
finitetime
Sep 26, 2013 10:54 PM
qepv25a
Mar 1, 2012 10:37 AM
Troglodyte
1983 - 2012 Ranger & B-Series
Feb 22, 2010 05:08 AM
frigerator
44
Apr 28, 2009 05:21 PM
