Offroad & 4x4
289 compression
Old Jan 10, 2000 | 08:42 PM
Nod's Avatar
Nod
289 compression
Can anyone tell me the stock compression reading for a 1968 289 in stock condition , any help is appreciated.
Old Feb 9, 2000 | 07:14 PM
f10073redneck's Avatar
f10073redneck
289 compression
According to my Ford Performance book, a 68 289 with the 2 barrel has a comp. ratio of 8.7:1
however, a 67 would have 9.3:1 comp. ratio. That's all i know.
Old Feb 11, 2000 | 09:51 PM
Katt's Avatar
Katt
289 compression
How can you convert a PSI reading to the ratio? My friend has a Buick 225 in his 68 Jeepster Commando and its ratio is 9.0:1 and the reading is 110PSI in most cylinders. Others are 115PSI.
Old Feb 11, 2000 | 11:06 PM
Trail_Rider's Avatar
Trail_Rider
289 compression
You guys are talking about 2 different things. Compression ratio is not the same as the compression reading on each cylinder. I don't know what it should be either.
Trail Rider
Old Feb 12, 2000 | 07:17 AM
DeenHylton's Avatar
DeenHylton
289 compression
What's important about doing a compression check is not the amount of PSI reading, but how close all cylinders are together in the range of readings you get. An engine in good shape will have all cylinders read within 10-15%, for example on a 6 cyl. you may have 4 cylinders reading 130-135 PSI, one cylinder at 125 and one at 120. This engine would be O.K. An engine in poor shape would have one or two cylinders reading much lower say 60 to 80 PSI or even lower yet. At this point you would have at least four things that would contribute to the low reading; 1. blown head gasket, 2. something wrong with the valves in the low cylinders (burnt,sticking,weak springs,etc.)
3. worn or broken rings 4. excessive detonation (broken piston ring lands, or hole blown in piston.)Deen
Old Feb 12, 2000 | 12:23 PM
Nod's Avatar
Nod
289 compression
Thanks for the information everyone,looks like all my cylinders are within 10 to 15 % of each other.Will go ahead and run it like it is .
Old Feb 13, 2000 | 04:26 AM
H8monday's Avatar
H8monday
289 compression
hunt1803
Mar 5, 2012 11:33 PM
harvy
Alternative Fuels, Hybrids & Mileage
Feb 1, 2011 08:19 AM
smoke n tires
Jan 18, 2005 08:48 PM
moose4130
13
Aug 24, 2003 06:42 AM
eclectix
Jan 2, 2003 01:57 AM
