dp tuner problem??
Old Oct 18, 2008 | 12:11 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Copper color =
Silver color =
Old Oct 18, 2008 | 01:09 PM
dsquared's Avatar
dsquared
Chris posted this about midway through the thread:
"All you need is a soldering iron and some solder, one pass of solder on each contact and your done."
Reps to you Chris!!
Last edited by dsquared; Oct 18, 2008 at 01:09 PM. Reason: Spell check running slow....
Old Oct 19, 2008 | 04:53 PM
ts_stroker's Avatar
ts_stroker
well got a new prob now i believe the dp is bad bc i installed a ts off of my buddies truck on mine and it worked just fine... truck ran perfect so i don't kno what is wrong with it.. hopefully dennis can help me out and replace it or somthin bc it ain't workin
Old Oct 19, 2008 | 06:35 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Something isn't right. Try the DP in your buddies truck. It makes no sense that one will work and the other won't.
Old Oct 19, 2008 | 07:07 PM
zx250's Avatar
zx250
Of the next Riffraff East
Originally Posted by Tenn01PSD350
...........It makes no sense that one will work and the other won't........
Unless the PCM code is wrong. DP is a little more PCM particular than the more generic TC,,,I think.
Old Oct 19, 2008 | 09:13 PM
ts_stroker's Avatar
ts_stroker
well i emailed dennis and he said that he used the right code on it. i put it on his truck bout 15min ago and with the dp on my buddies truck he got nothin. so i'm seriously thinkin that somthin is wrong with the chip now.
Old Oct 19, 2008 | 09:18 PM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
Sounds like the dp's jacked up. That's odd too, my buddy just ordered the DP, fried his first PCM installing it (his fault, dp was NOT in the truck when it was fried), got the stealership's new PCM in and cleaned, installed DP, nooooo fire. Not knocking Jody or Dennis, don't want anybody thinking that, just a coincidence
Old Oct 19, 2008 | 09:51 PM
big poppa's Avatar
big poppa
Man, this is something. subscribing.....
ts_stroker's Avatar
ts_stroker
yea i kno what ya mean. when i installed my ts the first time thats what happened. no i'm not knockin them what so ever and i don't anybody to think that bc dennis has been nothin but helpful in the hole process of trying to figure out what is wrong all i'm waitin on now is to see what he wants me to do about it (send it back to him or what)...hopin he says send it back and i'll send you a new oine...HOPEFULLY.
Old Oct 19, 2008 | 09:58 PM
big poppa's Avatar
big poppa
Hey Ryan, wait to hear back from Dennis, these guys are all great, it will work out..
Old Oct 19, 2008 | 10:08 PM
ts_stroker's Avatar
ts_stroker
all i am waiting for is for him to come into work tom morning.
Old Oct 20, 2008 | 07:39 AM
zx250's Avatar
zx250
Was the old (fried) PCM and new one from the dealer the same code? If not, that my be his problem.
Old Oct 20, 2008 | 07:54 AM
  #28
STROKIN'IT7.3
Not sure what code he had before, but assuming it was the same. He's also the type of person that would scrape the contacts down to a whole so i cant give him much credit lol.
Old Oct 20, 2008 | 09:00 AM
  #29
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
You will need to send it back to him for the chip to be examined. If anything is weird it will be replaced. A few things to check though. Our chips fit very snug on the J3 port connection. Run your finger nail across the traces and see if you can feel any more sticky silicone. If there is any it might be enough to cause a bad connection. Also if all of the tinning has been removed corrosion can occur that can cause a no start condition over time. The cable can not have any tugging from the back of the switch connection. The cable connection at the chip must have a tight fit as well. Any tugging and it will not work properly. Check these out and let Dennis know what you find.
Diane
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Oct 20, 2008 | 01:50 PM
  #30
big poppa's Avatar
big poppa
Hey Diane, don't know if you got my e-mail or not, my comp been kind of goofy lately but since your on here, i got a CB hooked up in my truck and when i,m driving and i key up the mic the truck dies, lights all come on the dash. If i put it in neutral and turn it off and recrank it over, starts right up. The hot for the CB is hooked up to the drivers side battery. Any thoughts. Sorry for the Hi-jack...
