Sponsored by: Auxito
Pulling CEL Codes ??
Old Oct 17, 2008 | 06:17 PM
2jhanna's Avatar
2jhanna
I tried seaching but did not come up with anything.
`97, F150, 4.2l V6, Auto.
Is there a way to pull codes without a scan tool ?
I have had other vehicles, including Fords, where it could be done with a jumper or keyon, keyoff sequences.
Thanks
Old Oct 17, 2008 | 06:59 PM
Help_Me!'s Avatar
Help_Me!
There are certain tests, such as for cruise control, where you can diagnose without the use of a scan tool. However, pulling codes from the PCM requires the use of an OBD II scanner.
Old Oct 17, 2008 | 07:01 PM
Help_Me!'s Avatar
Help_Me!
BTW: You can get that done for free at many auto parts stores, such as Advance Auto or, I believe, Autozone. I just went ahead a few days ago and bought an OBD II, an Actron 9185, on Ebay. You can get great deals. Mine was brand new and cost $130, compared to $230 or more elsewhere. If you go this route, keep checking and you'll find a steal.
Old Oct 18, 2008 | 04:06 AM
triton_2002's Avatar
triton_2002
advance doesn't do it, at least not in my area, but autozone does. get the codes and post them for more help. (watchout for the autozone guy and his advise, may or may not be any help, they can get the correct info off their computer system, if you get somebody who actually wants to help out)
Old Oct 18, 2008 | 08:29 AM
2jhanna's Avatar
2jhanna
Thanks, for the input, plan to attack it today.
Engine has a bad miss, at idle and driving. Hoped it was plugs, changed but no help. #2 may have been "wet" when I removed it. Thinking now, wires or coil pak.
Old Oct 18, 2008 | 12:23 PM
2jhanna's Avatar
2jhanna
Success. Used my timing light (have not used it in years), found that #2 was not being hit. Explained the wet plug. Moved wires around to prove they were good.
New coil pak and life is good again !!!
Never did have to pull codes.
Thanks again for responses.
Old Oct 21, 2008 | 02:26 AM
triton_2002
sounds good, getting the codes first usually gets you results faster, but if you don't need em, why bother....
have3fords
Bronco II
Oct 25, 2007 02:30 PM
turmanator
Bronco II
Sep 14, 2006 09:21 PM
LoneRanger89
1983 - 2012 Ranger & B-Series
Oct 22, 2005 07:43 PM
