Autolite 4300 won't idle after rebuild!?
Hi, all.
I'm brand new here. I have an 83 F-350 with a 460. A previous owner swapped out the original carb for a 4300 (D1SF AA). The truck ran great after warmup but was very hard to start when cold.
I noticed the booster pump wasn't working very well so I put a kit in the carb. After installing the carb back on the truck it won't idle at all. It sounds like it has a vacuum leak but there are none. The carb only has 2 vacuum ports on it. 1 for the brake booster & 1 for the spark advance. With both plugged it still won't idle. You can lay your hand over the the bores & it will idle which tells me TOO MUCH AIR. Idle mixture needles have no effect.
I'm at a loss since the only difference in the carb now from before is a new needle/seat..booster pump...pump discharge needle & gaskets. All metal parts were cleaned in Chem Dip & all ports blown out with compressor.
Any clues would be greatly appreciated.
bull jr
05-31-2015 04:29 PM
wyckedcombo17
08-15-2014 06:25 AM
KsCop
35
08-11-2014 03:25 PM
FlyingBronco
59
07-02-2014 01:07 PM
Bugzturbo
28
06-28-2014 02:32 AM
