Offroad & 4x4
C6 to overdrive conversion
Old Jun 7, 2011 | 09:24 PM
66bronco80's Avatar
66bronco80
Searching and Found This Thread
I'm new here and have been searching for answers regarding upgrading to an OD transmission and coupling it to an NP 205. What I've found so far is limited. First I'm working on my "79 Bronco with a 400 and C6/NP 205. I'm swapping in a 408 windsor stroker that will be mated to an E4OD out of a '95 F150 4X4. The E4OD was was rebuilt by PATC to their level 3 specs and should be bulletproof. To run the E4OD you do need a computer. The best that I've located is from Baumann Engineering. Do a search for the Optishift. This unit will alow a computer controlled transmission to be run in a non computer controlled vehicle. I ordered mine the other day and the cost for the Optishift, wiring harness, and wire loom was a little over $600.00. Now I'm at the point of trying to figure out which transfer case. I've used the NP 205 in every 4X4 I've had simple because they came in the vehicle. Due to their durability I'd like to stick with the one I have presently. The bolt patterns are the same on all ford transfer cases. I haven't found a definitive answer on mating the E4OD to the NP 205 so if anyone has some information on the feasability of doing this I'd be intersted in hearing about it. I also have the BW 1356 that came from the '95 parts truck that will be used if the NP 205 is not doable. Any input would be appreciated.
Old Jun 8, 2011 | 12:15 AM
fatdan460's Avatar
fatdan460
as far as i know the bolt patterns as well as spline counts on the shafts are all the same.
Old Jun 8, 2011 | 06:15 AM
66bronco80's Avatar
66bronco80
Yes, the bolt patterns for the tail shaft adapter are all the same. The spline count is the same. if you have the correct length adapter any ford specific transfer case will bolt up. What I've found from searching is that some claim the front driveshaft hits the E4OD, different crossmember needed, different transmission mount needed,etc. Can't find a thread by someone who has done the swap and the issues in doing it were that big of a deal.
Old Jun 8, 2011 | 09:33 AM
alpha/omega's Avatar
alpha/omega
So worst case...
you need to buy a $50 clocking ring and build a new trans crossmember.
2 hours and youre good to go.
Old Jun 19, 2011 | 03:41 PM
wyoming4x4's Avatar
wyoming4x4
manual shift auto!
hughes performance builds a manual shift auto. Something to consider and get your over drive.
Old Nov 28, 2011 | 08:42 AM
taylorcraftbc65's Avatar
taylorcraftbc65
OK guys, I want to go the OTHER WAY. I have a 1990 F-350 dualie king cab with the 460 and the 4EOD transmission.
The truck is starting to have big problems with the worthless the day it was designed computerized engine management system, and I am going to put a set of heads, intake, carb, and distributor from a 71 or 72bLincoln continental with a 460 on the engine. I am ALSO going to go with a C-6 tranny. I don't care about the mileage difference, I want RELIABILITY, and not needing a computer to tell the tranny what to do. Where I live in Texas, we get away with ripping the computers off the vehicles, I have already done that to two of mine, and they start and run better than they EVER did.
WHAT do I need to do, to put a C-6 behind the de-smogged 460, in a 2WD F-350?
Brie
Old Nov 28, 2011 | 10:04 AM
alpha/omega
Find wrench and turn bolts until tight.
Old Nov 28, 2011 | 11:25 AM
77mud's Avatar
77mud
step 1. remove crap from truck
step 2. put new tranny and carbed 460 back in
step 3 get you a ignition box and wire it up
step 4 continue polluting the world
Old Nov 28, 2011 | 11:26 AM
77mud's Avatar
77mud
almost forgot a 12oz curl is required with each of those steps
Old Nov 28, 2011 | 03:37 PM
taylorcraftbc65
THANKS Larry, I did not expect it to be that easy. At least when I get it so that it is a reliable runner, it will pollute far less the one of the 18 wheelers running up and down the interstates, and this truck lives in the most sparsely populated county in the state of Texas. (This county is the second largest in land mass in the State, yet only has 3,000 people living in it).
I'm waiting to see if the EPA forces the ranchers to install "Methane containment systems on the back of every cow in the State of Texas <G>.
Old Nov 28, 2011 | 04:34 PM
tjc transport's Avatar
tjc transport
i ain't rite
Originally Posted by taylorcraftbc65
I'm waiting to see if the EPA forces the ranchers to install "Methane containment systems on the back of every cow in the State of Texas <g>.
they would be better off mandating a "methane containment system" being put over the mouth of every politician in washington dc.
the amount of gas recovered in one week would power every powerplant in the country for a decade.
Old Nov 16, 2016 | 04:30 PM
bigfoot22's Avatar
bigfoot22
C6 AOD
Just thought I would throw this out there.
Dearborn Classics has a transmission package AOD 450HP -Small Block,FE,Big Block
$$$$$$$$ I guess if you want to play you gotta pay.
Old Nov 16, 2016 | 05:06 PM
  #28
tjc transport
i ain't rite
5 year old thread. i think he got the trans swapped already.
plus, he has not logged in almost as long.
campbell99
Oct 28, 2023 08:42 AM
garypettengill
Nov 8, 2017 08:16 AM
DeadThrone
Apr 13, 2017 07:30 PM
83f150xlt
Jan 31, 2017 09:44 AM
bulldogcountry1
Jan 13, 2017 12:11 PM
