Is This Even Right?
Old Oct 16, 2008 | 07:44 PM
dgsm24's Avatar
dgsm24
Is This Even Right?
ok i got a 94 f-150 4.9 4x4 e4od and my friend has a 96. when i got the truck the tranny was acting weird shift hard and stuff. Well my friend said his tranny was doing the same thing and he got his CAMSHAFT POSTION SENSOR changed and the tranny is perfect now he says, he has been know to bullcrap,.....so my question is, would this part being bad and replaced make the e4od work normal like he says? should i do it?....thanks you
Old Oct 17, 2008 | 06:33 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The CPS sends engine RPM data to the PCM. The PCM uses this to control the engine and transmission. If the signal is bad the trans won't work right, but I would also expect engine problems, too, unless your friend's truck is an IDI diesel. Those had a CPS that only was used by the trans.
Old Oct 18, 2008 | 08:43 AM
dgsm24's Avatar
dgsm24
yea his truck is the 7.3 diesel. the only engine probs i ever get is it stalls when parking, slow turning or backing up. so would u recommend changing the CPS
Old Oct 18, 2008 | 01:33 PM
Mark Kovalsky
The CPS has nothing to do with the engine on a '94 diesel. It's only there for the transmission.
Old Oct 20, 2008 | 07:04 PM
dgsm24's Avatar
dgsm24
so for mine the 94 gasoline one, would you say i need to change my CPS?
