Turn signal problem fixed.
Old Oct 15, 2008 | 11:43 PM
gfami45's Avatar
gfami45
Smile Turn signal problem fixed.
The problem was my right turn signal went out, plus the fuse number 11 would blow when I hit the brakes which also caused the shift interlock to malfunction and after checking everything and I mean everything I finally ran a new wire from the multifunction out to the rear turn signal and it works great.
Bought a new MFS and didn't help until later when even unplugging my headlights they would not turn off. Using the old MFS which I took apart to clean and try to see if the new MFS was different . What a nightmare. The lesson here is if you feel like your looking for a needle in a haystack trying to trace a short. Its saves more time and frustration to just run a new wire. Still have to finish putting things back together but I'm confident that all will be good.
Info: 1998 E350
V10 class C Motorhome/Winnabago
Old Oct 16, 2008 | 05:07 PM
CobraXP's Avatar
CobraXP
Glad you fixed your problem Gary!
And welcome to FTE! I'm going to move your thread to the Van forum so others can see your fix and might get help from it.
Kick back and enjoy the site!
