shuddering problem help needed
Old Oct 15, 2008 | 02:25 PM
jasvid's Avatar
jasvid
Hi Guys,
Great site here - I have learned a lot about my truck just reading/searching. I have searched for my problem, but haven't found what I am looking for.
My Truck - 1997 F350 Crew (diesel) w/ original tranny (I believe) and 187K on the odometer. I bought this truck in June 08. I use this for work and tow a lot of the time. Total trailer/load weight is between 3-8,000 lbs. Lots of interstate and some backroads.
The symptom - usually when towing a trailer, I will be driving around 45-60mph and the truck will start to shudder and lose power. This happens most often when going up a hill or getting up to highway speed. It is intermittent, but seems to be happening more often.
It seems to be something with the Transmission. Fluid seems clean and not burnt. Fluid level is good. How can I narrow down the problem?
Thanks,
Jason
Old Oct 15, 2008 | 02:37 PM
RMPC's Avatar
RMPC
Sounds to me like you might be having some torque converter issues ie the lock up clutch could be slipping or warped.. or the lock up solonoid isnt fully engaging the converter's lockup feature causing chatter. Do you use tow/haul mode or let it run in "normal" positiono all or most of the time loaded? I'd probably take it to someone you trust, that KNOWS Ford automatics...before the converter comes apart and smokes the rest of the transmission... I may well be wrong.. but I've seen this before and from what you are describing... sounds like converter.
Old Oct 15, 2008 | 02:54 PM
secondarychaos's Avatar
secondarychaos
Check the oil level.
the injectors are electronically controlled, hydraulically actuated.
Does it happen when the truck is warm?
Old Oct 15, 2008 | 03:06 PM
RMPC's Avatar
RMPC
I think he was indicating a problem with his transmission, not how his engine was running , secondarychaos...
Old Oct 15, 2008 | 03:20 PM
secondarychaos
Engine will shudder with low oil level, and kinda feels like it could be tranny.
i had a similar symptom happen to me. only some injectors will fire, because of a lack of oil.
Old Oct 15, 2008 | 03:40 PM
jasvid's Avatar
jasvid
Thanks for the replies.
-engine oil level is good - this is one thing I check regularly.
- this seems to happen whether the truck is warm or cold. I haven't noticed a pattern.
When I have a trailer on, I generally turn overdrive off unless I am on the interstate or an extremely flat and empty road. It does seem tranny related, but I am anything but an expert.
I forgot to mention that when I bought this truck I was told there was a Banks chip in there - don't know if that could have anything to do with it.
Can you test a torque converter or is it best to just replace it? When it goes out, does it always take the tranny with it?
Thanks
Old Oct 15, 2008 | 07:48 PM
tjbeggs's Avatar
tjbeggs
It could be the torque converter shuttering. An easy way to test and possible fix for quite some time is to change the transmission fluid but when putting new fluid in use ATF+3. Its a Chrysler fluid but I as well as my dad have used it for many years fixing the TC shutter on Ford of our customers. I used it on my previous truck that had a shutter when I bought it. Changed the fluid and 3 years and 40K later no issues. Sold the truck but its probably still going strong 2 years later.
