Help???Please!!!
Old Oct 14, 2008 | 10:07 PM
builtfordtough13's Avatar
builtfordtough13
Help???Please!!!
My dad is a tech at a for a ford dealer and currently has in his stall a 1994 F-150 with a 5.0L 5 spd manual, that has a miss on the #2 cylinder. He have done, relitive compression, relitive injector flow, both test showed ok. Has swapped plugs and plug wires, swapped injectors, tried a different distributor cap. On spark duration test when missing shows short duration. It only misses when cruisng at 40 mph and 4th gear when just tipping into the accelerator. It doesn't miss under hard accel or cruise. Has followed tsb for cross firing plug wires, didn't help. Would appreiciate any input. Thanks
Old Oct 14, 2008 | 10:12 PM
quicklook2's Avatar
quicklook2
did you read codes?
Old Oct 14, 2008 | 11:08 PM
builtfordtough13
It didn't throw any codes.
Old Oct 15, 2008 | 10:27 AM
quicklook2's Avatar
quicklook2
light does not always go on.
the question is did you hook up a reader and do all the tests?
Old Oct 15, 2008 | 10:41 AM
Virto's Avatar
Virto
Ford Fuel Injection for the proceedure.
Let us know the codes.
