Service unavailable
Old Oct 14, 2008 | 08:09 PM
OleGrouch's Avatar
OleGrouch
Service unavailable
I do not have service available for my 94 F-53 w/460 chassis under Bounder motorhome at my local Ford dealer, after sitting too many months without being used the check engine light comes on. If I could talk one of the mechanics to come check it out at my shop, would he have the available equipment to check this system and what is the electronic system designation used on this chassis ? Bobby
Old Oct 14, 2008 | 08:41 PM
gweeds's Avatar
gweeds
From what I understand in your post, it sounds like you need to pull your codes.
Old Oct 14, 2008 | 11:09 PM
McLeod's Avatar
McLeod
You should be able to read codes yourself with the assistance of a paperclip.
Old Oct 15, 2008 | 11:04 AM
alxsnmr's Avatar
alxsnmr
You can go to Ford Fuel Injection to find out how to pull codes then look up the codes to determine what the computer is seeing. It is probably something simple but check to make sure something hasnt used your wires to sharpen its teeth.
