Sponsored by: Real Truck
OBDII Problems
Old Oct 14, 2008 | 09:23 PM
polosabre's Avatar
polosabre
OBDII Problems
I have a 2004 F350 4X4 SD with a 6.0. I am trying to get any trouble codes and to see if a chip has been added. I don't know if getting info about the chip is possible with a code reader or not. My problem is that I can't get anything with the OBDII reader. It just tells me there is an error after I press the link button. Is there a different type of code reader that I need to be using?
Old Oct 14, 2008 | 10:14 PM
whalerron's Avatar
whalerron
You need a CAN ( CAN II?) compliant reader to pull the codes on the diesel trucks.
Old Oct 14, 2008 | 11:37 PM
rbaker6336's Avatar
rbaker6336
the code reader has to have ford enhanced software to read powerstroke engines
Old Oct 15, 2008 | 05:02 AM
F350-6's Avatar
F350-6
Welcome to FTE. As mentioned, you have to have the proper type of code reader. The cheap ones won't work.
Does your cigarette lighter work? The OBDII port and lighter are on the same fuse. If you have a blown fuse you won't get any communication to the reader.
Old Oct 15, 2008 | 07:07 AM
zx250's Avatar
zx250
Of the next Riffraff East
What they said ^^^^^^^^^^^^^^^^^. If you have two lighter outlets, check both. The main one is on the same fuse as the OBDII port. I'm thinking it's number 3.
Old Oct 15, 2008 | 07:16 PM
polosabre's Avatar
polosabre
OBDII Problems
Thanks for the info. No fuses blown, I don't see anything on the reader that says CAN.
