6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Job# Question
Old Oct 14, 2008 | 01:43 PM
seabee40's Avatar
seabee40
Job# Question
Hi Everyone,
Is there a way by looking at the truck to tell if its a job1 job2 job3 truck? Just got a 08 F250 the other day and really like so far!
Thanks Jim
Old Oct 14, 2008 | 02:17 PM
Carl Lassiter's Avatar
Carl Lassiter
Not sure but I'll try to help...
If you have the window sticker it says on there. Build date may be on door sticker, if it's built in any month of 08 it's a job3.
Old Oct 14, 2008 | 02:21 PM
seabee40's Avatar
seabee40
I dont have the window sticker I bought it used I will check the door
Thanks Jim
Old Oct 14, 2008 | 03:12 PM
66stang351's Avatar
66stang351
All dates below are approximate...
Job #1 Build dates June 07 or earlier
Job #2 Build dates July 08 - December 08
Job #3 Build dates January 08 or later
Old Oct 16, 2008 | 08:31 PM
letsroll93's Avatar
letsroll93
Something doesn't make sense on those dates.
Old Oct 16, 2008 | 09:11 PM
litespeedvortex's Avatar
litespeedvortex
actual difference
Other than build date, I believe there are physical differences between job 1 and 2 (please correct me if I am wrong)
Here is my question if you have latest software updates would a job 2 be the same as job 3?
The reason I am asking is i am looking for a truck. I am willing to travel to get it and I believe I have read in this forum that there are some problems with job 1. So should I make sure I have job 3 or will job 2 with updates be the same.
Thanks for your help
Old Oct 16, 2008 | 09:41 PM
66stang351's Avatar
66stang351
oops...the 08's in the Job #2 line should be 07's
Job #2 Build dates July 07 - December 07
brandon4's Avatar
brandon4
He means 07 on job2 dates.
Old Oct 16, 2008 | 09:43 PM
brandon4's Avatar
brandon4
Sorry, we posted at the same time. I've had job 1,2, and 3. My opinion is that all are good with the right flash and the venturee tee. My .02.
Old Oct 16, 2008 | 09:48 PM
66stang351's Avatar
66stang351
There were a couple of short periods of the Job #1 trucks that had injectors that were improperly installed or tested. Also, I believe the bad crimps on the radiators was a Job #1 issue.
The only noticeable physical difference between Job #1 and #2 is the longer chin spoiler on the Job #2.
Personally I wouldn't worry about the Job number at all. If the dealer does its job then it doesn't matter if it is Job #1, #2 or #3. If all the recalls/TSBs are taken care of there is nothing to worry about.
Old Oct 16, 2008 | 10:51 PM
litespeedvortex
Thank you
Thank you Stang
Old Oct 21, 2008 | 08:02 AM
RED DOG DADDY's Avatar
RED DOG DADDY
Ditto to stang he is correct ,.......... now to get the dealer on the same page, thats a different story
