Charging problem
Old Oct 14, 2008 | 01:24 PM
Spirit615's Avatar
Spirit615
Charging problem
Hello all,
So I have been wrestling with a charging problem the last 3 days. I thought it was the plug on the alternator but I have since cut off the old one and soldered on a new one, but I am still not getting a charge to my batteries. So I also swapped out the aternator with a new one. Still not charging. Any ideas??
Thanks
Tyler
Old Oct 14, 2008 | 02:12 PM
rbaker6336's Avatar
rbaker6336
are you checking for voltage at the bat+ post on alternator
may have to have alternatrt tested
think PCM controls the output also
Old Oct 14, 2008 | 02:28 PM
Spirit615's Avatar
Spirit615
Alternator tests fine. Not getting any charge to the batteries tho.
Old Oct 14, 2008 | 02:37 PM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
Could it be your wires? Check them from front to back. Does the battery hold a charge or just not receiving a charge?
Old Oct 14, 2008 | 02:54 PM
rbaker6336's Avatar
rbaker6336
check fuse 6 in power distribution box
Spirit615's Avatar
Spirit615
The battery cables are good. Do the wires on the top of the alternator run back into the cab at a point that might rub through them?
Old Oct 14, 2008 | 03:41 PM
DieselCamper01's Avatar
DieselCamper01
I was going to suggest checking the grounds but sounds like you already have. Hope it ends up being simple (cost wise anyway).
Old Oct 14, 2008 | 03:59 PM
Spirit615's Avatar
Spirit615
I checked number 6 fuse and it was good, but number 7 was popped. Everything works great now. I need to stat checking the little things first.
Old Oct 14, 2008 | 04:02 PM
rbaker6336's Avatar
rbaker6336
you are right I looked at it wrong,is #7,but at least you found it
Old Oct 14, 2008 | 04:19 PM
SpringerPop's Avatar
SpringerPop
On some Ford platforms this is true, but the 6G's regulator on SuperDutys is a "gray with gray cover" type, which is independent. No external control.
Pop
