i have a 08 f150 and i noticed when you use the one touch to open the sun roof it will open but not all the way. if you touch it again it will slide bac another 2 or 3 inches? why wouldnt it just open all the way?
ok just makin sure mine wasnt broken or something, like u said ford does that so people will go back to ford and ask if its broke then gives ford a reason to look at the truck and charge them for somethings else thats "broke"
I had the moon roof in my 04, man do I miss it. The reason it stops before going all the way back is to reduce wind buffeting. If you drive around awhile on both settings you will notice the difference.
I know if mine is on the second one and at higher speeds my headliner shakes like its out flying in the wind and man is it noisy. I always only open mine to the first spot
