Sponsored by: Real Truck
U joints
Old Oct 12, 2008 | 04:09 PM
ponch37300's Avatar
ponch37300
U joints
I was doing some searching for u joints for our trucks and came across alot of threads that says spicer is the best but hard to find. Anyone know where to get a good u joint? I would like to find a nice one i don't have to worry about breaking if i do some heavy towing or maybe even a sled pull or drag once in a while. THanks
Old Oct 12, 2008 | 05:58 PM
ReAX's Avatar
ReAX
Spicer is a great joint, but a precision non-greaseable is good enough for most uses. Non-greaseable or non-serviceable ujoints are a little stronger than greaseables, I've read they are upto 40%.
Old Oct 12, 2008 | 06:34 PM
ponch37300's Avatar
ponch37300
Thanks reax. How much shorter life span would you say non greasable joints have compared to greasable?
Old Oct 12, 2008 | 07:15 PM
ReAX's Avatar
ReAX
It's not really a problem I've ever worried about. I use non-greaseables and the only failures I've had were related to the yokes being out of spec. Time frame wise, I don't think I've kept a vehicle longer than 5 years after I replaced the ujoints so I don't know how long they could go. For the price, if you install them yourself, it's not worth the worry.
Old Oct 13, 2008 | 10:26 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Non-greasables will last LONGER then the greasable ones unless you grease them a lot.
Spicers are available all over, try Napa, just open the box and check the end-caps - they will say "SPICER" on them. Lots of aftermarket boxes with Spicer joints in them, just gotta check.
mabigredtruck
Jul 3, 2010 11:46 PM
lannondiesel
1997 - 2003 F150
Nov 27, 2008 09:56 PM
79pos
1997 - 2003 F150
Jul 8, 2007 11:10 PM
Blown 331
Oct 9, 2006 11:31 AM
Cool1996
Mar 30, 2005 08:05 PM
