engine gasket question
Old Oct 12, 2008 | 01:37 AM
9.ford.5's Avatar
9.ford.5
ok so i got a headgasket job commin up probably monday (funnnnn) anyways i was wondering if an exhaust manifold or header gasket or any other exhaust gasket that might exhist could cause enough of an exhaust leak that it could kill the mpg and stuff by sucking air into the exhaust and throwing the O2 sensor, or am i lookin at a bigger leak like cracked headers or something?
thanks for your help
Old Oct 12, 2008 | 08:06 AM
quaddriver's Avatar
quaddriver
the exhaust system is pretty much positive pressure and the O2S measures the ratio of oxygen to whatever it happens to get. I can imagine that unless you had one manifold off, the other on, it would not make a diff.
