I have a 2000 Ford Expedition with a 4.6. Just today I decided to clean it up real good and I washed the engine off....... now its got a bad miss but not engine light. What do I do???????
Do not spray a 4.6 or a 5.4 with the Coil Over Plugs. You will get the miss you are getting now. If you are lucky it will go away after a day but if it shorted the coil out you will need to replace it. A code reader can be handy at this point since it can show you which coil is bad. The fine folks in here can also help you out: https://www.ford-trucks.com/forums/forum27/
