Offroad & 4x4
4wd swap out front ends? questions
Old 01-10-2001, 12:13 PM
supersixer49's Avatar
supersixer49
supersixer49 is offline
I have aqquired an 88 F-150 I-6 5spd 4X4. I currently have a 96' F-150 2wd I-6 5spd manual. I know that there are some differinces in the frames as far as structural members for strenght, But all of the measurements line up between the two. And as far as setting up the tranny and transfer case, well thats a cake walk.......... If anybody has any pros or cons please document, It would be much appreciated.....
Old 01-10-2001, 03:43 PM
billyb's Avatar
billyb
billyb is offline
this is easily done. go to 4wd sectin and look for "86 4wd conversion " or something like that. i have done this and there are replies in that thread from me and others who have done it.
there are other posts in that section and in suspension section.
you will have to watch for abs brakes on later model, and for brakes being different.
Old 01-10-2001, 05:44 PM
supersixer49
I started today and got the front end off of the 4x4 and probably gonna work on the tranny and transfer case tommorrow. With no furhter adoo, I probably gonna mount everything in the front end this weekend. Got new ball joints, tierods, seals, bearings and all that good money consuming stuff ordered today from napa. Hopefully I'll be driving it to work on monday, lookin like a 4x4. Then next week(I go back to work next week) I'll need to take a look at the differences between the ZF and M5OD as for as bolt ups go, and the cross members.
Old 01-11-2001, 10:24 AM
DannyP's Avatar
DannyP
DannyP is offline
So are you saying that one of these F-150's is equipped from the factory with a ZF tranny? A few of us on here were wondering if this ever happened. Typically ZFs are only found in 250's on up.
Just curious.
DannyP
89 F-150 4x4 former EFI I-6 now carbed 351W, Edelbrock heads,cam,intake,carb.
MSD 6A, ZF, Sterling 10.25 with 3.55L's.
Old 01-11-2001, 10:50 AM
supersixer49
Yes sir, you are correct, this does have a factory ZF close ratio transmission in it. Didn't think so at first cause it said f-150 on the fenders, but after gettin under it, its got the diagnal webbing, and the part numbers match. Also, for some reason this truck was considered a heavy half, its got 4200pd springs under the rear. thats what whitman ford said.
Old 01-11-2001, 02:52 PM
DannyP's Avatar
DannyP
DannyP is offline
I hope the 4x4 is the one with the ZF. If not, and you want to hang a transfer case on the ZF, you will have to change the rear case and the output shaft and a couple other odds and ends. If you need more info just yell and I can look over the schematics again.
DannyP
Old 01-11-2001, 04:58 PM
supersixer49
The 88' 4x4 is the one with the ZF in it. So that makes the swap even sweeter. Got all my parts this morning for the front end, and I'm about half way through it now. Its nice to have my work laptop out in the shop to look stuff up on the net. I just have to watch using dirty fingers.
Old 01-12-2001, 01:43 PM
proeliator's Avatar
proeliator
proeliator is offline
Rij1
New Member Introductions
09-19-2016 01:29 PM
Jfieldsfamily
09-01-2015 08:12 AM
saskpwr
12-13-2010 05:55 AM
85-300man
05-27-2006 07:11 PM
Brown89f150
05-08-2004 04:32 PM
Quick Reply: 4wd swap out front ends? questions
