Fuel Pump Eccentric
Old Oct 11, 2008 | 10:22 AM
rwlacks's Avatar
rwlacks
Fuel Pump Eccentric
Need help: 78 Ford 460 question is does this engine use a 1 or 2 piece fuel pump eccentric ?? Also where can i buy this ??
Old Oct 11, 2008 | 01:58 PM
scrapyardking's Avatar
scrapyardking
the only ones Ive ever seen were 2 piece. As for a new one you might be S.O.L. I tried everywhere to get one for my 302 and nobody could get it. But one finally surfaced on ebay and I snatched it up.
Old Oct 11, 2008 | 11:51 PM
rwlacks's Avatar
rwlacks
True but
I have seen this on most small blocks just tryinf to figure out the 385 series
Old Oct 12, 2008 | 12:00 AM
Thunderjet4x4's Avatar
Thunderjet4x4
1978 should be the 2 piece one. I would think most parts places should have them-phone.
Welcome to the FTE!
Old Oct 12, 2008 | 07:32 PM
Franken-Truck's Avatar
Franken-Truck
I might still have the 2 piece from my 460 rebuild. If I can find it, you can have it.
Old Oct 12, 2008 | 08:09 PM
mark a.'s Avatar
mark a.
I've got a few laying around too. I wouldn't use a 1 piece.
Old Oct 13, 2008 | 12:53 AM
Dirt racer's Avatar
Dirt racer
I bought my last one piece on ebay too part number C8SZ-6287-A. I think the 2 piece will work fine. It has a little tab and a bolt to hold it in place. The one piece is thicker and stronger in my book but only has the bolt hole. I modified a one piece in the last 2 460/429's I built. I cut a hole in the eccentric and installed a roll pin so if the bolt comes loose at all it will still work. You can't drill it with a drill bit, too hard. But have to use a carbite grinding bit. Soo I think the 2 piece is better in the unmodified state.
stercorarius
Jul 2, 2016 09:52 AM
Dimitri13
Nov 12, 2015 11:43 PM
Willz74
Oct 13, 2015 01:04 AM
rcfreed
Jun 26, 2015 01:20 AM
medino03
May 14, 2012 10:24 AM
