What's the trick??
Old Oct 11, 2008 | 12:16 AM
alconk's Avatar
alconk
What's the trick??
I'm installing a anti-rattle kit (new weatherstrip) in my 79 but can't keep it in the channel. IT keeps falling out and I've tried everything to get it to stay in the groove. So what's the trick??
Old Oct 11, 2008 | 12:33 AM
drfelgood5's Avatar
drfelgood5
adhesive should do the trick.
Old Oct 11, 2008 | 12:38 AM
alconk's Avatar
alconk
Well from the factory no adhesive was used. There is a groove in the metal window channel that allows the weatherstrip to slip under. I might try soapy water......
Old Oct 11, 2008 | 07:53 AM
Balzomedic's Avatar
Balzomedic
What i've tried before with some success is hair spray. When its still wet it kinda works like a lubricant but when it dries its sticky and the excess cleans off easy. You might give it a try. I have also held a string on the rubber for areas that the rubber gets crammed into and there is also a little flange of rubber that has to flap over outside (hope this is making sense) after you cram the rubber in there you pull the sring and it pulls that part of the rubber into place, works great on windshields. You might give it a try.
Old Oct 11, 2008 | 08:38 AM
4x4 Bart's Avatar
4x4 Bart
Use a wooden paint stick and hammer to gently tap it into the bottom of the channel on both sides, then it should stay in place.
Old Oct 11, 2008 | 12:20 PM
fmc400's Avatar
fmc400
MSEE
Mine popped in with no problems. I bought my kit from Mac's.
Old Oct 11, 2008 | 12:34 PM
alconk's Avatar
alconk
I bought these from LMC Are Mac's any better?? What is the web site there?
Old Oct 11, 2008 | 02:32 PM
80F100man's Avatar
80F100man
I wouldn't go to all the trouble of takin' or shippin' them back just use some clear silicone here and there, it'll stay in place and no1 but you will know they've been 'stuck on'....
Old Oct 11, 2008 | 04:10 PM
fmc400's Avatar
fmc400
MSEE
I don't really know; mine was by a company called "Repops" or something like that. It was in a long yellow box. LMC is known for carrying sub-par foreign-made junk. In general, Mac's has higher quality stuff. I don't know what brand LMC's anti-rattle kit is, maybe it's the same, maybe it's different. I do believe Mac's is a site sponsor because I think that is how I found them.
Old Oct 11, 2008 | 04:42 PM
m78's Avatar
m78
LMC wont work period. I sent mine back
Old Oct 12, 2008 | 07:11 AM
saleen065's Avatar
saleen065
I got mine from LMC and had zero problems. I took mine and pinched it as I installed it and fed it into the channel that way. Once it was in place I rolled the window up tight and let it sit that way in the sun to get it to seat. I used silicone spray on the backside to make it easy to slide in.
Old Oct 12, 2008 | 07:14 PM
Dr. Dirt's Avatar
Dr. Dirt
I don't know what LMC's quality is, but usually they don't have too good of a reputation for body panels......you get what you pay for.
