C6 trannys.
Old Oct 9, 2008 | 10:45 PM
FoxRacin17's Avatar
FoxRacin17
C6 trannys.
Hi, Im not too familiar with Fords auto trannys. Im lookin at a truck with a 302 and a C6. Are those trannys decent? Ive always had manual trannys in everything. The truck has a new C6 in it. It sits on 39s with 5.13 gears too if that has anyhting to do with it. It wont be driven that much. Possibly pull a small trailer from time to time. Am I gonna have problems with the tranny if i get that?
Old Oct 10, 2008 | 01:46 AM
85e150's Avatar
85e150
C6 is a strong trans, & has been out for years. Fairly inexpensive compared to the later OD transmissions. If it was done right, it will be the least of your worries. Automatics soak up a bit more power than manuals, and the C6 soaks up a bit more than many other automatics. If you are going bracket racing, you need to worry about that, but otherwise, like I said, the least of you worries.
If you are going to tow anything, consider a trans cooler.If it doesn't have one already) Send the fluid to the aftermarket cooler first, then to the stocker in the radiator, then back to the trans. That way your trans fluid stays at the right temp and doesn't run too cold in light load cold weather situations.
Good luck.
Old Oct 10, 2008 | 08:22 AM
Lazy K's Avatar
Lazy K
Good luck.
Couldn`t agree more. I have a C6 in my F250, would recommend it to anybody.
Old Oct 12, 2008 | 08:26 AM
FoxRacin17's Avatar
FoxRacin17
its a mildly tuned 302 and it has 5.13s in it. its not like its trying to do it with stock gears.
thanks for the help guys. much appreciated.
Old Oct 12, 2008 | 08:36 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What year is this truck w/a 302/C6?
Have you verified it actually is a C6?
The reason I ask is, no F100 or F150 w/a 302 came with a C6 till 1978, all prior years used C4's.
1978/79, both the C4 & C6 were available with the 302.
C6 = 17 transmission pan bolt holes.
C4 = 11 transmission pan bolt holes.
If a 1969/77 F100 or 1975/77 F150 w/a 302 has a C6 now, it wasn't there originally.
David LaPell
Apr 2, 2014 04:50 AM
David LaPell
Apr 2, 2014 12:19 AM
4x4ford33
18
Jan 24, 2014 10:56 AM
wolk464
Dec 18, 2011 06:11 PM
fordbum
Dec 12, 2000 04:39 PM
