1977 f150 burning oil please help
07-19-2014, 10:25 PM
on
I have a 1977 F150 ranger with a 5.8l 351m and the speedo says 12,699.im trying to wonder why is puffing blue smoke out the exhaust,any help?
07-19-2014, 11:09 PM
Rings shot, cylinder walls worn, valve stem seals hardened, valve guide wear .... speedo saying 12,699 could be 112,699 or 212,699 for all we know.
Just guessing here ....
07-19-2014, 11:16 PM
If it's only on start up, that points to the valve seals/stems. If it's a light haze all the time, then more often than not it will be the rings or cylinder walls.
07-19-2014, 11:18 PM
So that means simply rebuilding the heads?
07-20-2014, 04:10 PM
It could be just rebuilding the heads, yes.
Does it smoke On start up only or constantly?
If it's on start-up you could yank the valve covers and do a visual inspection. It's an old truck with an old engine, this kind of thing is normal.
Wassup599
11-27-2018 05:29 PM
krazyness
07-02-2016 12:58 AM
joshcwa
09-30-2012 02:46 PM
351beast
22
07-03-2006 10:19 AM
KJKozak2
05-23-2005 08:02 AM
