Oil disappearing issues
Old Nov 25, 2018 | 03:22 PM
Wassup599's Avatar
Wassup599
Hi all, i have a 86 ford f250, 460ci, t19 4speed truck and have had a on going issues with oiling disappearing on me. I go through around a quart a week. Now here is where im at a loss, it doesnt smoke at all unless i drive it for more than an hour. Then all hell brakes loose and im clouding an intersection. It use to be when i turned so i did valve guide seals thinking that could be an issue and it has continued. The last time i had it happen i was going down hill, out of gear at idle and it was smoking a lot. And it was towards the end of my drive and had been downhill with no load also and had no issue. When i did the seals it was with the heads on and i didnt hear a difference from cylinder to cylinder. Any ideas would be greatly appreciated
Old Nov 25, 2018 | 03:59 PM
FuzzFace2's Avatar
FuzzFace2
Valve guides
Dave ----
Old Nov 25, 2018 | 06:46 PM
Franklin2's Avatar
Franklin2
How many miles on the engine?
Old Nov 25, 2018 | 07:59 PM
Wassup599's Avatar
Wassup599
I have already done valve guides, and my odometer reads 74k but is a 5 number, was owned by 1 person and used lightly the last 10 years so i could see 174k being the right millage.
Old Nov 26, 2018 | 05:57 AM
FuzzFace2's Avatar
FuzzFace2
You said you did valve guide seals not the guides, 2 different things.
Guides the heads have to be pulled and a machine shop do the work.
No matter how good the seals are if the guides are bad they have to be done too.
Dave - - - -
Old Nov 26, 2018 | 11:33 AM
Wassup599's Avatar
Wassup599
Ahh sorry guess i was the one who didnt read properly lol, ok yeah that does make sense as well. Guess i get to save up for a full engine rebuild then.
Old Nov 26, 2018 | 05:28 PM
Franklin2's Avatar
Franklin2
I have had engines exhibit unusual oil burning at certain times, and on one of them it was caused by the oil return holes in the heads being clogged with crud. These holes are at outer corners under the valve covers.
Old Nov 26, 2018 | 05:44 PM
Wassup599's Avatar
Wassup599
Yeah i looked at them when i did the seals but i might just pull the covers and make sure they are fully cleared out again, thanks.
Old Nov 27, 2018 | 03:52 AM
Ken Blythen's Avatar
Ken Blythen
Do you have aftermarket rocker covers? Some do not have any (or adequate) baffles at the PCV valve hole; consequently oil is sucked into the engine, via the PCV valve & intake manifold, & burnt.
Old Nov 27, 2018 | 08:15 AM
Odisvan's Avatar
Odisvan
I tried seals too on a S-10 I had, to no avail. Quart a week of daily driving. Couldn't see it burning either. I would have pulled the heads and had them worked but I decided I can get just as good a mileage out of a full size truck, so I bailed on it.
Old Nov 27, 2018 | 05:14 PM
Franklin2's Avatar
Franklin2
Been there done that. It's hard to beat the oil separators on the original valve covers.
Old Nov 27, 2018 | 05:29 PM
Wassup599's Avatar
Wassup599
The covers are stock, the PO had atleast pulled the heads once as i could see aftermarket valves in the heads but with stock rockers and an aftermarket cam set up. I will probably run it till i cant anymore the way it is if the drain holes are clear and look into a 12v with a nv4500 since i wanted a 5 speed anyways and doing a 12v woth a donor would run the same price as a rebuild woth upgrades.
joshcwa
Sep 30, 2012 02:46 PM
351beast
22
Jul 3, 2006 10:19 AM
KJKozak2
May 23, 2005 08:02 AM
la350
Mar 10, 2005 06:59 AM
snakebit12
Jun 4, 2001 08:12 PM
