Suspension Help
Old Oct 9, 2008 | 08:35 PM
kg6tib's Avatar
kg6tib
Suspension Help
Can someone post a picture or 3, of the front end of an 80-86 4x4. specifically where the i-beams connect to the crossmember on each side.
Im modifying a skyjacker 4" lift for a 86' f-250 4x4 to fit my 80' F-150 2WD.
If i dont mod it, im just going to make new drop down brackets out of 3/16" plate.
Thanks guys! -Josh
Old Oct 9, 2008 | 08:40 PM
Franklin2's Avatar
Franklin2
Here's a picture. Look at blow up view "w" and "x".
http://www.autozone.com/images/cds/g...3d800a8dba.gif
Old Oct 9, 2008 | 10:43 PM
86F250BIGBLOCK's Avatar
86F250BIGBLOCK
are you going to break up a complete skyjacker kit for a 80-86 F250 If its just a few components thats one thing, but if its complete kit thats a crime!!! lol arent those upwards of $1000 for a kit? I really dont see it working being that the f250 has leaf springs and you should have coil springs, am i right? Or are you just modifying the bracket?
Old Oct 10, 2008 | 02:39 AM
kg6tib's Avatar
kg6tib
the the kit i have is for an f-250 IFS with a dana 44. im eather going to modify my crossmember to bolt on to the skyjacker dropdown brackets, or fab up some new ones and sell the skyjackers. I picked up the dropdown brackets, drop pitman arm, and blocks for $40. so i know i got a deal on it. the drop pitman arm alone is worth $80 new.
so this is the kit i think i have.
http://www.skyjacker.com/image/search/pdf/F2840TK-A.pdf
Photo #1 and 2 are the brackets i have.
I looked at the photo that Franklen2 posted and that seems to be the same configuration as my 2wd. the skyjacker drop down brackets are suppost to be positioned and welded to the center section of the x-member rather than the stock location of the side.
any ideas? remember i am working with 2wd i-beams. -Josh
Old Oct 10, 2008 | 07:25 AM
uncle.stosh's Avatar
uncle.stosh
The drop brackets on the F250 are totally different and will not work.
Trust me, I've been contemplating the same thing only using F150 brackets on an F250.
Would you consider trading me? I was going to do an SAS, but have changed my plans and want to lift my TTB for now.
Let me know.
Old Oct 10, 2008 | 12:09 PM
kg6tib's Avatar
kg6tib
what kind of brackets do you have? how much lift?
Old Oct 14, 2008 | 06:05 PM
kg6tib's Avatar
kg6tib
uncle.stosh What lift do you have? I am considering tradeing.
Old Oct 14, 2008 | 06:28 PM
uncle.stosh
There is NO NEED TO YELL. A PM would have been sufficient.
It's a Skyjacker kit on an 87-91 4WD F150.
I was going to try and use it on mine, but after doing some research I found out that the drop brackets aredefinitelydifferent.
I can get you some pics tomorrow if you'd like.
Old Oct 14, 2008 | 06:30 PM
kg6tib's Avatar
kg6tib
sorry i cant PM. it wont let me. i added you to the buddy list but when i go to PM you it says " you dont have privileges"
how many inch lift? do you want to shoot me an email to talk about it?
Kg6tib@gmail.com
