Modular V10 (6.8l)
Pinging problem?????
Old Aug 11, 2010 | 10:27 AM
  #46
krewat's Avatar
krewat
FTE Leadership Emeritus
That sounds like you have a vacuum leak. If the computer is seeing a bank lean, that IS a problem that has nothing to do with needing higher octane.
Old Aug 12, 2010 | 10:26 PM
  #47
mevdp1's Avatar
mevdp1
pinging:vacuum leak?
Huh. I put on a locking gas cap last summer, when problems began. any chance?? I will put OEM cap back on and look for vacuum leak. thxs!
Old Aug 13, 2010 | 10:43 AM
  #48
krewat's Avatar
krewat
Dunno, but these trucks do not report problems with the evap system, so who knows what it might be doing.
Old Aug 24, 2010 | 09:57 PM
  #49
blazer2000's Avatar
blazer2000
I have an '03 4.6L F150 and have the same symptoms. Part throttle rattle at tip-in while cruising. Also a rattle starting at 4K rpm WOT. To me this sounds like LOAD is not being calculated correctly, knock sensor advance is messed up or enrichment queues are not being triggered.
Tinkering with a programmer for a while I've found that these same conditions are basically what happens when I've added too much global spark on a car without knock sensors. I think this is true because tip-in load and high rpm WOT load seem to be two extremes these systems see.
I am going to change the knock sensor type from 1 to 0 and see if that is enough to disable. There are a lot of other parameters so I guess I'll find out.
Other items to consider.
EGR flow actually helps to reduce knock, maybe there is insufficient flow due to sticky valve. ( have yet to explore this.)
Dirty ACT sensor that is not reporting correct temp and thus not pulling enough timing for ACT inputs. (tried new one, did not help me)
Old Mar 12, 2011 | 09:56 PM
  #50
digler's Avatar
digler
Pinging?
Hate to revive an old thread, but can anyone tell me what this pinging sounds like and if my truck was doing this when would I notice it. I have an 01 f350 with a 4.30 rear diff. Twice in the last 5 months the truck has stalled suddenly after coming to a stop, no stumble, couldn't tell until I stepped on the go peddle and nothing, put it in neutral and started right up. The truck runs smooth, no hesitation and gets around 9.0 mpg no matter what it does. The only sound that has questioned me occurs at cruising speeds on the highway and occurs only between 60-65mph and is not rpm dependent, the sound is a high pitched whistle kind of like a turbo. Any ideas?
Old Mar 12, 2011 | 10:08 PM
  #51
wpnaes's Avatar
wpnaes
Pinging to me sounds like a hand full of marbles rattled around in a 4 qt pot. The other thing to check is an ailing fuel pump for your sudden stop.
Old Mar 13, 2011 | 10:52 AM
  #52
digler's Avatar
digler
Fuel Pump?
Thanks, I thought that if the stall was a fuel problem I would have some stumbling before it died, the two times my truck stalled was after coming to a stop, and sudden, I couldn't even tell it died until I hit the gas and nothing.
BCHauler
Modular V10 (6.8l)
18
Nov 10, 2012 04:28 AM
ham-n-swiss
Jun 3, 2009 03:59 PM
90taz
Modular V8 (4.6L, 5.4L)
16
Oct 4, 2007 04:21 PM
Shawn MacAnanny
Feb 21, 2007 10:27 AM
thinkirish
1983 - 2012 Ranger & B-Series
May 9, 2004 02:15 AM
