Want to change the fluid in my 05 Excursions 4R100 transmission and Transfer
case and the manual says to use MERCON and notes that MERCON and MERCON
V are not interchangeable, I want to use Mobil 1 Synthetic ATF and it indicates that
it is suitable for; Ford*MERCON, MERCON V, MERCON: so wanted to know what yea think
should I use or not?
Yes, you can use it. Since your owner's manual was printed Ford discontinued MERCON and changed MERCON V to be compatible with all transmissions that used to use MERCON.
Is there a difference in transmission oil quility between what walmart sells compared to the local parts store house brand? Are there any standards they all have to meet? For instance is there any difference between Motorcraft Mercon and Autozones house brand?
There is a standard for all fluids that have any MERCON V or MERCON SP license. The license is only granted after they submit fluid to Ford for testing. If it doesn't pass the tests they can't say it's MERCON V fluid. They can skate around it like AMSOIL does by saying they recommend their fluid for transmikssions that require MERCON V. AMSOIL does not submit fluid for testing, so who knows if the fluid is compatible or not.
Never had any problems with my trans. until i mixed the fluids.
mercon and mercon v....
did do a complete flush and re load with mercon...guess it was to late...
goes "ok" but has a shudder now...
