Torino diff identifcation
Old Oct 9, 2008 | 12:16 PM
figleaf11's Avatar
figleaf11
Have a torino diff in my '50 F1 trying to ID the ratio, tag states as follows
WE8-AV 4LC
3. 00 9 8428
Any and all info will sure be appreciated, I thought it was a 3.0 but in figuring engine rpm/wheel dia/tranny (C4) at 1.1 I sure don't come up with rational numbers. I get actual65mph + minus at 3000. formula sez 82.???? I'm using a 28 Inch dia tire (275/60/15 dunlop).
Ralph
Old Oct 9, 2008 | 01:07 PM
85e150's Avatar
85e150
3000 for 65 mpg comes out more like a 3.91 ratio.
Even with a little tc slip, you should be around 2400-2500 max.
Calculator to check with if you don't have one or want to double chk:
Novak Conversions - Gearing & Gearing Math for Jeeps
Make sure you are getting two shifts out of your trans. Doubt this is the problem, as 65 comes up at 3440 rpm with a 3.0 gear if you are in the 1.47 second gear. (or is it 1.46?)
Double check your tach and speedo also. (1 mile take 1 min? Odo read accurately?)
Old Oct 9, 2008 | 01:36 PM
figleaf11's Avatar
figleaf11
torino diff identification
Thanks 85, my speedo is dead on. I was reading the diff ID tag as a 3.0 due to markings. Guess its not. Yes I am getting 2 shifts.
I really need a read on the tag, interested in what it came off and what nomenclature means. Any suggestions?
Old Oct 10, 2008 | 01:54 AM
85e150's Avatar
85e150
Well, that does read 3.0 ratio if what you posted is right. Numberdummy has the rundown on these codes & a couple others. He might be by, or you can PM him.
Does it light the tires right up in first?
Old Oct 10, 2008 | 10:09 AM
figleaf11's Avatar
figleaf11
torino differential identification
Nah, it won't light up anything but it sure is the first one across the intersection, I jacked it up and counted driveline/wheel revs and it takes 1.5 driveline revs to 1 wheel rev?????
