Trans Temp guage install...
Old Oct 8, 2008 | 12:17 PM
DieselBeast01's Avatar
DieselBeast01
I have been searching for a while, but I can't seem to find a really good write up on a transmission temperature gauge install. I need to know how to run the probe that actually reads the temp. Help me out.
Old Oct 8, 2008 | 12:24 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There's a black hex head plug in a port on the driver's side of the trans, towards the front, just above the pan. Remove the plug and install the sender there. Then run the wires to the gauge. That's about all there is to it.
Old Oct 8, 2008 | 12:26 PM
Ponyboychris's Avatar
Ponyboychris
Gauge Installations at DieselManor- 1999-2003 7.3L Powerstroke
Slides 12-14 & 28-33 tells the whole story.
Old Oct 8, 2008 | 12:34 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
I only say this because I did it a few years ago when I did mine, "do not over tighten the sensor"! I actually broke mine off inside the test port where it screws in.
Old Oct 8, 2008 | 05:28 PM
danskool's Avatar
danskool
Go Bills !
A couple rounds of Teflon and just snug up. Not to tight like Chris said.
Teflon tape if you have a two wire sender. One wire don't use any.
