Stuck engine
Old Oct 7, 2008 | 09:47 PM
Ford79's Avatar
Ford79
Stuck engine
I have a 460 that is stuck(siezed). I need to get the converter off the flexplate to mount it to a stand, but can't rotate it to get the last 2 nuts off the converter. Is there a trick to getting at the last 2 nuts off?
I guess if I need to, I will remove the heads and try to get it broke free so it will rotate, but I'd prefer not to do that.
Old Oct 8, 2008 | 10:13 AM
northern 7.3's Avatar
northern 7.3
Temporarily Deactivated
i did have this problem a few years ago but i cant remember for the life of me how i did it. i may have popped off the oil pan and worked the crank out with the flexplate and torque still on it then took it off after. i'll try to remember in the meantime but that may be how i did it.
Old Oct 8, 2008 | 04:25 PM
mcdonaldm's Avatar
mcdonaldm
or you can just unbolt the transmission and pull the converter off with the engine and then get to the bolts. makes a mess, but easier than any other way.
Mike
Old Oct 8, 2008 | 04:29 PM
mcdonaldm's Avatar
mcdonaldm
actually i might not of read your post wrong. if the transmission is already off, then i am not sure except for trying to break loose the engine of getting at the nuts. i was thinking that you still had the tranny bolted to engine. should read and then let brain digest info first.
sorry.
Mike
zephyrprime
Dec 28, 2015 02:46 PM
maxride
Apr 5, 2014 09:46 PM
livetoride20000
Aug 3, 2009 07:17 PM
jbirklid
15
May 5, 2009 09:33 PM
daveplot
Mar 21, 2004 02:53 PM
