Cold-Air Intake
Old Oct 7, 2008 | 12:35 PM
Bart R's Avatar
Bart R
Cold-Air Intake
Has anyone ever tried the cold-air intake on the V-10? If so, any improvements in gas mileage and power(not that I'm lacking for power)?
Old Oct 7, 2008 | 12:42 PM
shorebird's Avatar
shorebird
I have a K&N on my van. Don't know any numbers but the seat of my pants says it's good.
Old Oct 7, 2008 | 02:00 PM
1's Avatar
I was wondering the smae thing, but I think the exhaust side is the bigger cork in our engines then the intake side.
Old Oct 7, 2008 | 02:34 PM
Deno346's Avatar
Deno346
I have the AME Brute Force... Sounds great... when I first installed it seemed to have a bit better throttle response (maybe I'm nuts) but now I'm used to it.
Tire Rack has 1 kit left for $246.00
PM me if you want it...
Old Oct 7, 2008 | 03:52 PM
Matt M, PA's Avatar
Matt M, PA
I have a Scan Gauge that monitors the incoming air temp. It's always within a degree or two of ambient. I can't imagine such a slight change would make any noticeable difference.
Old Oct 7, 2008 | 04:07 PM
Deno346's Avatar
Deno346
Great point... hence my comment "maybe I'm nuts"...
AEM specs
PEAK POWER GAIN:
5.4HP @ 3750RPM, 10 FT-LBS @
2500RPM
While this is not likely to be noticeable I would imagine the larger amount of air being fed into the intake could possibly help the throttle response ....
again I may be nuts.. .
Either way, to each his own...
Old Oct 7, 2008 | 04:26 PM
shorebird's Avatar
shorebird
1 I'm in agreement with you on the exhaust problem. I am planing on getting a set of Banks Torx Tubes one day. They are the only ones that I know of that fit the E-350 because of the engines offset in the frame.
Old Oct 7, 2008 | 04:55 PM
Trucker51's Avatar
Trucker51
Heres on off of ebay that was like $70? Works great!
