...Doing a leveling KIT install right now... need help...
Old Oct 29, 2008 | 11:47 PM
  #46
redrush40's Avatar
redrush40
Originally Posted by tylus
make sure you aren't cross-threading it!
tylus,
oh ya, I did watch out for that one!! thanks bro!
You know what it was... it was that factory style nut that had the plastic lock ring on top... it got some little pieces in it...
GOT IT OUT no problem after some elbow grease!
GREAT GREAT GREAT NEWS:
I just finished it up!!!!
I got a HELLBENT STEEL 2.5 total inch lift in the front!
Man, that does really jack it up compared to stock!
NOW, if anyone runs into ANY type of problem at all... just email, PM or contact me.
I would be MORE than happy to try to help.
I just about ran into every problem known to man, with this kit!
And it sucked that I did it with hand tools, limited space, and basic floor jack!
BUT IT IS DONE!
...and PHOTOS TO COME!!!!
TONY Z.
#40
Old Oct 30, 2008 | 12:06 AM
  #47
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
you got me laughing with that post. glad it finally came together for you.
Old Oct 30, 2008 | 12:33 AM
  #48
redrush40's Avatar
redrush40
About the Passenger side install...
I actually had trouble getting the spring to compress because...
When I put the jack under the lower control arm, it actually teeter-tottered over the driver side (the whole truck did).
I got this little idea, that I would put the driver side tire back on (so the driver side wouldn't go downwards).
Wouldn't you know, the L.C. arm came up enought to get the upper ball joint nut started!
***Word of advice though, at full drop of the passenger side spring, it does actually hit the spring itself.***
That is a fact with the HBS leveling kit.
Sooooo, now for some alignment and new tires, and also a headlight adjustment... and I will be able to get a photo of it.
PS. also not sure though, but rough check with tape measure it seems as if it is totally even lift on front and back.
If a little high in the front, can anyone please direct me towards a back lift kit?????
Rock on!
TONY Z.
#40
Old Oct 30, 2008 | 01:18 AM
  #49
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
AutoSpring 3" Rear Block
AutoSpring 1 1/2" Rear Add a Leaf
I suggest the 3" block. You unbolt the 8 axle nuts, let the axle drop down some, remove the 2" OEM block and replace with the 3" AS block. Install new Grade 8 u-bolts and your done
The Add a leaf is slightly more difficult, and will make the ride somewhat stiffer...but it will also allow you to carry more weight.
I personally have the 3" block. I was wanting the 1 1/2" AAL, but the shipping to Hawaii would have been $80...vs the 3" block it was a no brainer in my case.
I'm just waiting for a free moment on a weekend so I can do the install. My wife hasn't let me be free for the 1-2 hours it would take
Old Oct 30, 2008 | 09:34 AM
  #50
cgah04's Avatar
cgah04
so by adding the block in the rear would the it return to the stock rack just higher? 3in block inthe rear sounds like alot
Old Oct 30, 2008 | 10:23 AM
  #51
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
2" block OEM
3" AS Block will replace it
so only 1" of rear height added. My truck sits dead level when the gas tank is empty. a full gas tank and she kinda sits butt heavy. also when a load is in the bed.
the 3" block will give me a very slight rake, and keep it from being butt heavy
Old Oct 30, 2008 | 04:17 PM
  #52
cgah04's Avatar
cgah04
after adding a rear block would u have to align the front or no? i wouldnt think so but jw
Old Oct 30, 2008 | 04:19 PM
  #53
cgah04's Avatar
cgah04
whos done the add a leaf and how to they like it?
Old Oct 30, 2008 | 04:20 PM
  #54
silver05fx4's Avatar
silver05fx4
i know mine sits dead level with my 2.5 hbs leveling kit ...becusae if it didn't i was going to get blocks
Old Oct 30, 2008 | 04:23 PM
  #55
cgah04's Avatar
cgah04
im sitting dead level 2 but i like the idea of the leaf spring supporting more weight when i tow a trailor or have stuff in the bed so it doesnt sag down
Old Oct 30, 2008 | 05:28 PM
  #56
silver05fx4
its will make the rear sit higher and stifer which is good for towing large loads id thats what you need but if you just after look blocks are the way to go
Old Oct 30, 2008 | 10:44 PM
  #57
redrush40's Avatar
redrush40
Silver05,
question here for you...
With the HBS 2.5 inch lift on the front, did you ever try to haul something heavy (over say 100-500 pounds)?
If you did, does the back end sag at all?
Question is since, I will probably be hauling a quad (600-700 lbs) on the back of my 05 FX4. I just don't want to be blinding the on-coming traffic with my headlights, with a load in the back.
PS. does the 1 inch total lift blocks in the rear effect the driveshaft angle at all???? (has anyone expericened vibrations?)
TONY Z.
#40
Old Oct 30, 2008 | 10:47 PM
  #58
redrush40's Avatar
redrush40
PPS. I am getting 275/70R/18 Hancook Dynopro RF10/ATm tires on soon!
These tires are a total of 33.1 inches diameter I was told.
Is that a good tire to use? A good size and tread to use?
TONY Z.
#40
RobbyMartin
2004 - 2008 F150
Apr 15, 2013 01:00 AM
kamikid
Massachusetts Chapter
May 16, 2012 10:39 AM
kamikid
New Hampshire Chapter
May 1, 2012 12:03 PM
GIP1979
2004 - 2008 F150
Dec 29, 2007 11:15 PM
hellbent
1997 - 2003 F150
Feb 22, 2007 06:11 PM
