My GPS is stuck in map mode. Function buttons on side do not work; powering off and back on no help. Even pulled the fuse to reset the disk, no help. any ideas?
Alan
Try holding down preset buttons 3 and 6 at the same time for about 5-10 seconds. This will get you into the diagnostic screen. Also check each button and make sure none of them are stuck in the "in" position from debri.
Thanks...ran the diagnostics and the hard key test and went back and all buttons functioned. Now I can enter new destinations. Great advice, I did not see the 3 & 6 preset diagnostics in the manual.
Alan
