6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4 breakdowns.....
Old Oct 6, 2008 | 07:32 PM
op_06's Avatar
op_06
6.4 breakdowns.....
anyone else having trouble with these trucks? I drive an 08' F-550 at work and have already shopped it 3 times with only 21,000 miles. The radiator was the first to go, after that came the water pump, and last week they replaced thermostat and some other coolant related items. When running right, pulls fully loaded 40' duel tandem like a champ. What gives with the new engine? Our 06' F-350 just came outta the shop with a new head gasket @67,000. Much more of this and the company's changing brands.
Old Oct 6, 2008 | 08:08 PM
dzldude's Avatar
dzldude
sorry to hear that you are having problems.iv got 36k on mine.not 1 problem.i havnt even put a radiator on it.
Old Oct 6, 2008 | 08:14 PM
senix's Avatar
senix
there was a recall on the radiator, poor design to save money I am sure, once you do the fix that is it. As for the water pump issue, that is just bad luck.
Make a couple hundred thousand and one of them is gonna have a problem
Old Oct 6, 2008 | 09:10 PM
J.T. Guitar's Avatar
J.T. Guitar
As far as the 6.4, it shouldn't give you anymore problems.
The 6.0 is notorious for head gasket problems... due to faulty bolt design. Notorious is probably not a strong enough word, as this is probably the main catalyst for the Ford/Navistar... Eehh-rrr... shall we say, issues?
Bill explains it better than I do... http://www.powerstrokehelp.com/6lite...tmare/1of2.asp
Old Oct 6, 2008 | 10:23 PM
Lead Head's Avatar
Lead Head
The earlier radiators had a crimping problem on the end tanks from the supplier, and the end tank would start to separate from the. There was also a recall on some piece on the cooling system going to the coolant reservoir. I believe it let air into the cooling system, possible causing damage to the radiator and other cooling system components. So I say that truck should be fine.
Also, remember that the 06 is a 6.0, which were known for head gasket problems. Problem is fixed with a set of ARP headstuds though. The 08 has the new 6.4, a much different engines with a lot less problems then the 6.0
Old Oct 7, 2008 | 08:18 AM
richfaa's Avatar
richfaa
Defective DPF on a early Job 1 in the first month..now 15K miles and not a single problem.Tow a 13K plus fifth wheel all over the country.
Old Oct 7, 2008 | 08:41 AM
J.T. Guitar
Good to hear... safe travels!
Old Oct 7, 2008 | 10:19 AM
69cj's Avatar
69cj
With all the EPA mandates all 3 of the big truck mfgs. are having their problems. Neighbors Duramax has had 3 EGR's, an engine wiring harness and leaking P.S. pump. Roll the dice on any new diesel with all the new regs.
Old Oct 7, 2008 | 11:20 AM
J.T. Guitar
"The most terrifying words in the English language are: I'm from the government and I'm here to help."
Ronald Reagan
Old Oct 7, 2008 | 05:33 PM
thatsme's Avatar
thatsme
Thumbs up
Ronald Reagan
That is excellent!!!!!
Old Oct 7, 2008 | 09:28 PM
Dustin1690's Avatar
Dustin1690
That is to bad sorry to hear about all the troubles but so far I have heard lots of good about the 6.4 and not so much the bad other than fuel mileage
Old Oct 7, 2008 | 09:40 PM
150ford's Avatar
150ford
Who said the other brands are not having trouble. Right now it looks like Dodge is having the most serious problems. A service truck for a local manufacturing firm has been in the shop about a half dozen times for the EPA crap. It doesnt run right at all an they cannot figure out the problem. I suppose the 6.o has put a bad taste in the mouth off a lot off people but the 6.4 is well built motor. I got to look at the internals off one at a powerstroke display an i was really impressed how beefy the engine was built
Old Oct 9, 2008 | 03:58 PM
op_06's Avatar
op_06
Other than those 3 breakdowns, the 550 pulls like a champ. Dustin, it avg's 7-8 empty, and drops down to 5.5 when pulling fully loaded. For those in the market for the bigger light duty trucks, be prepared to shell out some money on fuel. Spent over $2000 on diesel last month. As for our 6.0 350 goes, aside from the head gasket runs great also. We regularly put over 5k on the bed, im surprised the springs are still holding up on it. The most we've hauled on the bed is 8k and I couldnt fit 2 fingers between the bed and tires. (Flat bed on both trucks) My GVW was a little over 18500. Talk about a big *** ticket for getting caught.
Old Oct 9, 2008 | 08:22 PM
J.T. Guitar
It sounds like you're using them real good! LOL
Old Oct 9, 2008 | 10:03 PM
Dustin1690's Avatar
Dustin1690
5.5 mpg fully loaded yikes but it is a 550 thats a big *****
