IP pump adjustment question
Old Oct 5, 2008 | 09:42 PM
bigblackF250's Avatar
bigblackF250
Sometime this week I am going to start installing my Banks turbo kit, question is this, it will be later in the week when I start the install and I want to go ahead and adjust my pump up 3 flats now for the turbo and I will have to drive my truck a couple of day's with just the pump turned up, will it hurt anything? I do not have my pyro installed yet but I will only be driving it less than 50 miles total and not be pulling a load, anyone think I will have a problem doing this?
Also is 3 flats about right?
Thanks, Rob
Old Oct 5, 2008 | 10:05 PM
PLC7.3's Avatar
PLC7.3
Does the Banks not require the screw on the rear of the IP to be readjusted ........ not sure about the 3 flats internally too.
Old Oct 5, 2008 | 11:30 PM
Blueovals&Blacksmoke's Avatar
i would say 2.5-3 flats would be about right 3 if you really wanna smoke people out and 2 if you just want a little bit of smoke under load.
it wont hurt a thing unless you stomp the throttle and hold it there for a while, after i get my pyro in im going to turn mine up to about 2-2.5 flats.
Old Oct 5, 2008 | 11:54 PM
LCAM-01XA's Avatar
LCAM-01XA
2-3 flats make a N/A truck smoke like a steam train, I had mine up there for one day and for the 25 miles I drove the truck I outsmoked every vehicle on the road, including an oldschool Peterbilt tractor named "The Smoke House". Dunno what's the effect on EGTs, but it can't be good - just keep that in mind, you may be seeing high EGTs even under light load.
Old Oct 5, 2008 | 11:56 PM
well if the egt's start climbing all he has to do is slow down a bit and drop a gear and let the motor breathe lol
Old Oct 6, 2008 | 12:11 AM
LCAM-01XA's Avatar
LCAM-01XA
Oh, I was talking about you man, cause you're the one without turbo. And I'm not talking about lotsa smoke under lotsa load, I was barely on the throttle and accelerating slower than a fully-loaded gravel train.
Old Oct 6, 2008 | 12:16 AM
idk i might go to 2 flats right now i think its at about 3/4 a flat
Old Oct 6, 2008 | 04:19 AM
bigblackF250
PLC,
The instructions do call for internal adjustment of the pump but they only give a 60 degree figure and that was where I was getting the 3 flats from, it does not say anything about an external adjustment, is there one there that I should do instead?
Old Oct 6, 2008 | 05:42 PM
LCAM-01XA's Avatar
LCAM-01XA
60 degrees would be 1 flat, as in 1/6 turn = 1/6 of 360 degrees = 60 degrees. The external adjustment is on the back of the IP, right above the head where all the lines attach, and tis covered by a plastic cap. How you use that adjustment, I dunno.
Old Oct 6, 2008 | 08:25 PM
bigblackF250
OK, I found the external adjustment screw, so what would the setpoint be for that compared to the internal adjustment Banks requires?
Old Oct 6, 2008 | 11:42 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The external screw is only on 92 and later IP's.
It is not the one down by the IP head.
In this picture the external screw is under the bottom of the h in shut.
Angled at about 45 degrees, brass screw with a lock nut around the outside.
What that screw does is set where the IP starts to deliver more fuel at RPM wise.
Hold the screw with a screw driver, loosen the nut, turn it out about 1/2 turn and tighten the locknut.
A pyrometer is a very good idea before any fuel adjustments are made.
Once you have one, you will really be surprised at how easy it is to raise the EGT, even at stock settings.
Old Oct 7, 2008 | 04:28 AM
bigblackF250
Could not see your picture Dave but what you are describing sounds about right, I will dig into it some more when I get home from work. By the way mine is a early 93 model. Would it be better to do the adjustment here or internally?
Thanks
Old Oct 7, 2008 | 06:20 PM
Dave Sponaugle
The internal screw only adjusts the max fuel delivery.
The external screw adjusts how much fuel at lower RPM's.
A balance of the two is best, between them you can keep black smoke to a minimum at all RPM's and have decent power.
