my striker pin on the drivers side is threaded and i don't know what to do! it looks like a pain to replace the plate inside the door frame! what should i do chase the threads out? and can i buy a new pin and plate? i am in the process of a resto so the pins where way off from the po who had bondo in the old doors so he had to move it to match the body lines! i have new doors so i need to move it back to original position! and in the process the pin threaded when i loosened it, and i think it was loose from when the idiot previous owner moved it back in 97 !
drill out the hole and put a helicoil on... thats all i can think of
That's probably your best bet if the threads are gone. The new striker may make it's own threads. I'm not sure if you can get that size of re-threader or not.
